Question about Microwave Ovens
Panasonic Microwave oven starts, then stops. By "resetting" sometimes, it starts and runs.
  • 1 more comment
  • mopspopsnapl Nov 15, 2009
    This Panasonic Microwave Oven has a stainless steel cover with a mirrored touch pad, and consumes 12.7 Amps, 1,460 Watts (Model Nbr NNT964SF). It is not easy to see how to remove the touch pad to get to the circuit board. I would have to remove the screws at the back of the unit and slide off the stainless steal sheath.
    I am describing this because I want to make certain you know my model.
    OK. But my microwave unit needs to be fully removed from its stainless steel shroud first, just to get to the interior of the unit. The stainless steel cover is held on by a half dozen shallcross screws, which are too small for my existing shallcross bit. So I need to go out and find the right size shallcross bit to fit the screws.
    Since, I'm opening up the entire microwave unit, do I need to first discharge the magnetron, which appears to be located behind the touch pad.
  • mopspopsnapl Nov 16, 2009
    Thanks. My microwave is clear of any obstruction. My problem is I don't have the right size and type of screw driver to remove the machine screws holding the cover in place. hopefully, I'll be able to find the correct driver today. I'll let you know.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please let me know when you find the correct size of screw driver to remove the machine screws holding the cover in place.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 16, 2009
    Brigadier General:
  • 4,090 Answers
Make sure the airflow around the unit is free from "clog"" If the unit has shifted back towards a wall it may not have enough airflow and this will cause it to shut down.
Thanks for using Fixya
  • 6,927 Answers
This microwave has a circuit board behind the push button panel,it can be removed by releasing some small plastic tabs,remove it an d clean the circuit board with a spray electric contact cleaner.A build up of moister,and food juices build up on the board and are shorting the circuit board out,this happens on these models of pannasonic.
Posted on Nov 15, 2009
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Nov 15, 2009
    I did not say it would be easy,but this has fixed a lot of them for me.
2 Suggested Answers
  • 8909 Answers
SOURCE: Panasonic Microwave Oven NN-S262BF It starts to
There is not a lot you can do except call the Panasonic Repair Man. It may need either a magnetron or Invertor board.
Neither are user repairable.
Posted on Jan 31, 2011
How to reset the clock on a Panasonic NN-SA651S microwave.
hi carol.
try this,if this does not work go to the link.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set. You are now ready to use your new Panasonic Microwave Oven. When you first turn on yourmicrowave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . .
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How to reset the clock on Panasonic NN SA651S microwave Google Search
Nov 07, 2017 | Panasonic Microwave Ovens
Why does NN-SN651x Microwave sometimes starts, sometimes not ?
Adj door latch switch assembly. It is not aligned properly preventing the door hooks to engage.
Aug 31, 2014 | Panasonic Microwave Oven NN-SN651B
Why panasonic microwave oven stops working
when it does that is power supply. they do that. change power supply and see what happens
Apr 29, 2014 | Panasonic Nn-sd681s 1 2cuft 1200 Watt...
Panasonic NN-H665BF starts and will run for about 5 seconds and then stops without heating up anything.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 [
Aug 07, 2011 | Panasonic NN-S541 Microwave Oven
Our Panasonic 1350 microwave no longer heats food.
heatman101
ghdgh
May 13, 2010 | Panasonic NN-S963BF Microwave Oven
My NN-T695 Panasonic microwave oven starts up for two seconds then cuts out before doing any warming?
I'm having the same problem with the same model microwave. It has taken hard use for a long time, but now it will (sometimes) start and then stop after a second or two. I think it's a loose connection, because a couple of times I got it to work by rapping on the back or side.
Mar 02, 2010 | Panasonic NN-T695SF Microwave Oven
Child sign in window of microwave ,cant start it panasonic
On my NN-L738BA there is a Child Lock feature.
You set the child lock by pressing the Start button 3 times.
If the Child Lock is enabled it displays the word :CHILD".
To disable this feature on my microwave the manual says to
press the Stop/Reset 3 times.
Check your manual for the Child Lock.
Mar 06, 2009 | Panasonic NN-S541 Microwave Oven
Shuts off but everything else works
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 08, 2008 | Panasonic NN-S542 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
