Question about Ritek (R80JS52RDCB100) 100 Pack 52x CD-R Storage Media
Samsung 52x cd writer
Often the cd tray does not open. Once open there is no problem with closing
    Genius:
  • 1,003 Answers
Use memorex brand cdr they are the most compatable (readable media ) to many cd& dvd writers .
the reason the cd writer dosent open often is because its usually trying to read poor quality media use good quality memorex cdr you will see a big difference in performance.
Posted on Jan 15, 2008
Why does my cd tray keep opening in my laptop. its apresario cq62-421nr
The sensor inside the cd writer does not recognize the closing of the tray. Hence it keeps opening all the time. To stop it from opening hold the tray pressed when it closes for some time. The tray may stop opening. Sometimes it works. Else you have to repair or replace the CD writer.
sonsunny
Jul 04, 2011 | Computers & Internet
I have a CD "tray" in a audio CD player that is
Have you have tried shutting down the pc, and then turning it back on? if that has forced it to close the drive, it's likely dead.
there is a chance the power cable fell off the back, but it's unlikely.
If it's dead then you'll probably need to swap it for a new one. Best to take the old one out and down your local computer shop, pc world, dixons, or something.
I reckon it's an EIDE drive cos of the 52x CD-ROM indicating it's age, so it'll have two connectors, a flat ribbon and a white power connector. Just make sure you get a replacement with the same connections.
Most new drives will be SATA and incompatible.
Jan 22, 2011 | Samsung SC-152L (dssm52xcdoem) Internal...
I have samsung dvd writer, when i open it the tray gets automatically closed. help me out!!!
Dear it means that your dvd writers belt is scuffed from somewhere now either you have to change the belt which can be done by only at service station or through any hardware engineer
Mar 09, 2010 | Computers & Internet
My dvd-writer/cd-writer combo will not open?
look a tiny hole in the front of the CD/DVD drive use a paper clip to pull out the tray, when you have the tray out use the EJECT bottom in the drive to close and wait 3 seconds and press again to open, do this at least 3 times.
Fosg2000
Feb 24, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
I have a Lite-On DVD writer that will not open unless disk is in.
The problem is with ur DVD Writer Tray, Some of the reason ur dvd writer tray get jammed. For the temporary purpose you can use the manual eject pin hole Technique.
Nov 07, 2009 | Computers & Internet
My dvd writer opens and closes automatically it wont stay open
This occurs when there is dust accumulated in the inner part of the tray. Send it for a service
Jun 25, 2009 | Samsung Computers & Internet
My DVD ROM does not burn some cd,when it tries to burn the tray opens its self.how do i stop the tray from opening and closing its self automatically
Either the CD is full or the quality of the CD is inadequate to burn it with your CD writer.
Try a good quality CD, or lower the writing speed and make sure it is an empty CD.
Jules
Apr 20, 2009 | Samsung Computers & Internet
Door
Hi abdu
The problem is that at some stage you or someone else forced the cd open or closed, but not to worry, it's not broken. What happened is that the gear that pulls the tray in, mite have slipped a tooth or two. You'll have to open it up. Take the top cover off. It has four small screws holding it. When you take the cover off, the gear system should reveal itself. Now the gear that pulls the cd tray in and out must me ajusted. Before you open the dvd writer, make sure it is in it's utmost closed position. Very Important!. There should be a screw in the centre of this gear. Carefully unscrew completely. Now it depends on which direction the gear turns when it close the tray. Seeing that it doesn close completely, the gear turns anti clockwise to close. Lift the gear in a up sliding position and turn it one teeth clockwise, press the gear back, fasten the screw and test. If it still needs more adjustment, repeat the process with another teeth clockwise. Note if it worsen that it doesn't close, then you need to reverse the process and move the gear anticlockwise, but make sure to mark the teeth that it was originally on when you opened it.
Hope this helps
Cheers
Deon
Sep 10, 2008 | LG (GCE-8527B) CD-RW Burner
Samsung Internal 52x CD-ROM follow-up question
When i am trying to close my tray then the tray goes inside and comes back after several times of my try sometimes it may work or sometimes it won't work .and the cd is also detecting sometimes i fed up with this plz give a solution...
May 28, 2008 | Samsung (SC-152) Internal 52x CD-ROM Drive
Nero burn CD with different speeds.
Your burner can only achieve high speeds towards the end of the burning progress as the data burned reaches the outer areas of the disc. Burning starts at the center of the disc - the more the laser moves towards the outer end, the faster the burning speed gets. I have a 20x burner and 18x discs, and every burn starts at about 6-7x and then gets progressively faster, until the last 20secs of the burn it actually burns at 18x.
Feb 19, 2008 | Ahead Software Nero 6.0 (60045) for PC
Ritek (R80JS52RDCB100) 100 Pack 52x CD-R Storage Media Logo
85 people viewed this question
Top Ritek Electronics - Others Experts
Marvin
Marvin
Are you a Ritek Electronics - Other Expert? Answer questions, earn points and help others
