Question about GE Refrigerators
I THINK I LEFT THE DOOR TO THE FRIDE SLIGHLTY OPEN FOR 5 DAYS. DO I NEED TO TURBO-COOL IT OR RESET IT. I DONT HAVE MY MANUEL
    President:
  • 1,218 Answers
Good day,
If it's cooling O.K. then just let it go.
If not, (I've never heard of turbo-cool) My professional advice, is to unplug the machine, leave both doors open overnight and restart.
A real pain, but is by far the best long term solution.
Posted on Nov 15, 2009
2001 Audi a6 that I am thinking of buying but owner said the left turbo is bad that when you push hard there seem to be steam coming from the engine what could that really be is it just the turbo that's...
It is not the left turbo, there is only one turbo. IT is the LEFT turbo intercooler. Looks like a radiator. IT uses coolant from the cooling system to reduce the temperature of the turbo. They are about 100 dollars to apiece. You could drive it BUT if it gets bad you loose all the coolant and must stop or you ruin the whole engine.
Aug 20, 2014 | Cars & Trucks
01 vw beetle.battery died.recharged now remote wont lock or unlock doors.lights flash,switch inside works????????
You need to reprogram your key to the car. Also you have to reset the electric windows by putting them fully down..hold button for 5 sec...put fully up and hold for 5 sec.
I cant, of hand recall the reset for the key fob, but i dont think it needs a diagnostic tool, just a procedure.
check out the vw forums...bound to be in there.
Roger
Mar 07, 2014 | Bosch 01 Vw Beetle 1.8lt Turbo Mt Ecu Ecm...
The fridge door was left open overnight and doesnt cool
the turbo cool function is for rapid cooling, when first switching on after defrosting or moving unit,it will switch off automatically when near your set temperature.(+5C)
Jun 21, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Refrigerator is not working...
nongbu2380 lets see what happens. Those model remember how long the door was open. It's in the memory so it tried to keep up the cooling while the dore was open and may have missed a defrost. You may get it to cycle correctly again by unplugging for a few minutes so the control board will reset. If you continue to have problem I will send you the instructions to put the refrigerator in self diagnostics or to manually reset the board. Hope to help, let me know, Sea Breeze
Sep 13, 2009 | GE GSH25JFR Side by Side Refrigerator
Fan making noise but stops when door opens
try defrosting, it might be touching ice build up. you can check by pressing the knob switch in front after defrosting one day
May 09, 2009 | Refrigerators
Pink fluid under refrigerator
Loklok...no, I don't think so. The only fluid in refrigerators is an oil which is sealed in the cooling system and we know you are cooling. Your fridge may need a full defrost. This occurs because you may have left items uncovered and the moisture condensed in the cooling coils. It could also be the result of improperly sealing doors caused by dirt/ bad gaskets or the like. Best thing to do: shut it off, open the doors and let it defrost fully for a day. Clean the condenser coils under the unit with a long brush. Dry out as best you can and restart. You'll likely be okay. Make sure your freezer side is at about 0-5 above...refrigerator side 35-45. Use a regular thermometer and leave the door closed for at least an hour. (Do these measurements a day after you've restarted.)
Jan 28, 2008 | Kenmore 25.1 cu. ft. Side-By-Side...
Ge Side by side model PSS26MSRSS
I had the same problem with mine, but I bought the 5 year warranty from Sears. They sent me a new board (Part Number WR55X10552) and the problem stopped. This is a common problem from what the guy at Sears told me. I put the board in myself in less than 20 minutes. It's a very easy job. I saw a few of these boards brand new on Ebay for $55.00. The board is different than the one that came with the refrigerator. It's been updated, so now when you open the doors the fan motor stays on (mine always shut off when I opened the doors with the old board). Good luck!
Jun 20, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
232 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
