Question about Amana AGDS902 Gas Kitchen Range
The stove is locked, how do I unlock it so I cn open the oven door?
  • 187 Answers
You might have the oven scheduled for cleaning. If so, clear that. You also might have a child safety lock that was put on by accident. If you can not find a clear button, try to reset the oven cleaner for a minute or two and have it shut off. If none of the above works, go to your breaker box and shut the power off. It should reset the electronics. I hope this works, I see a lot of complaints about Vikings not opening after cleaning.
Posted on Nov 15, 2009
Testimonial: "Thank you, the turning off the fuse did it. Thanks for the advise. "
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Door is lock
How to unlock Kenmore oven - YouTube
? 1:07
www.youtube.com/watch?v=xnwnLi8Ld5I
Jun 30, 2013 - Uploaded by Imi Chitterman Kenmore oven lock and unlock after self cleaning. ... What should I do to get my oven door open please? I pressed the start button but it didn't ...
www.partselect.com/.../Range-Stove-Oven/Door-Will-Not-Open-After-S...
If the door will not unlock at the end of the clean cycle then you may have a problem with the oven temperature sensor. Most electronic control ovens will display ...
Nov 05, 2015 | Kitchen Ranges
Went to take pie out of the oven and door will not open?
How to Clear the Oven Lock Mechanism on a Kenmore Stove
homeguides.sfgate.com > Buying Real Estate > Down Payments
Move the locking lever, situated just below the oven door handle, to the left if yourKenmore has a mechanical lock. Newer models unlock automatically upon the ...
? 1:07
Nov 05, 2015 | Kenmore Kitchen Ranges
VIKING STOVE DOOR IS LOCKED AND WILL NOT OPEN , STOVE WAS IN A SELF CLEANING MODE AND DOOR WON'T OPEN AFTER CYCLE COMPLETE
unplug or turn off breaker to stove for 10 minutes...then try to gently open.....the oven has to be completely cool before it will unlock....when cleaning is done release lock before turning cleaning off
Nov 28, 2009 | Viking VGSC306-4B Gas Kitchen Range
When cleaning the stove i touched my accident the
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
F90 code flashing and i cant reset it
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Oven door locked will not open
try putting the stove in self clean when it goes in for about 1 minute cancel the self clean see if it opens.
Nov 30, 2008 | Tappan 30IN ELEC IGNa Oven
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
Frigidaire stove door locked
I've had a similar problem - door is locked. If the door is open - locate the light switch and hold it in for a few seconds. Sometimes it makes a noise and resets the lock. Otherwise, push the Clean button and the Cancel button on front of oven simultaneously and hold for about 30 seconds. The ?locked? light should disappear. If it is working, you?ll hear a mechanical hum as it resets.
May 10, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Amana AGDS902 Gas Kitchen Range Logo
311 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
