Question about Honda Garden
No pressure on lance maybe problem with pump - Honda Garden
  • 90 Answers
The valves need to be checked,
the springs are probably rusty and broken,
Posted on Dec 03, 2009
Why do i have low pressure?
Maybe sucking air in through a chemical valve (if it has one)
maybe new pump seals
a valve suck open in pump.
worn lance jet.
www.Flowjet.co.uk http://www.flowjet.co.uk/
Jul 22, 2014 | Husqvarna 3300 PSI 3.2 GPM Gas Pressure...
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
Water does not come out of the lance when I squeeze the trigger
HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
May 31, 2010 | Northstar Professional Series Pressure...
Pump working - no pressure from hose. B2002?
Sounds to me that you may have a blocked high pressure jet.
Dec 13, 2009 | Karcher K2.26 Electric Power Washer
1800 power washer will not run - power is getting to on/off switch
Maybe just the pressure switch is stuck or you have trapped pressure in the lance. Try without the high pressure hose and then activate the pressure switch on the side of the pump as this may not be letting the machine to statr if its stuck.
Nov 12, 2009 | Campbell Hausfeld 1800 PSI Electric...
Lost pressure
try this
dissconect hose and lance , and check for water flow through the machine , if theres none or just a trickle then you may have gunk in your inlet filter ( usually a small plastic gauze insert just where the water feed hose connects )
then start machine , check for high pressure flow ( you will see the difference )
its quite common for the nozzle on the lance to become blocked
if all this seems fine but the lance is vibrating then you have a blockage in one or more of your pump valves .
Nov 11, 2009 | Honda Pressure Washer PSI 3000
My pressure washer seems to be leaking at the lance connection can anyone help?
Take the lance off and look to see if there is a missing o-ring or maybe a crack
Jul 03, 2009 | Karcher PSI Electric Pressure Washer
Pressure pulsating when pulling trigger
you have a restriction in the nozzle end of the lance. clean with paper clip.
if not you have some dirt in the pump head valves which need cleaning
Mar 22, 2009 | Garden
Motor pulsates in rapid sucsession little pressure,with lance removed continuesto run normal,new lance same problem,my estimation is the valve at fault that controls the pressure switch
It could be the pressure switch itself at fault. If it is reading (in error) too much pressure, it will shut off for a second and then pulse as you say.
If the pump seals have gone, you may get this effect too. Depends if the pump is being controlled wrongly, or just malfunctioning itself.
Jun 18, 2008 | Washing Machines
Garden Logo
41 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
