Question about Gateway GT4016 Desktop PC
Gt 4016 when I finally can get the button on, the fan runs for about 15 seconds then shuts down.
  • 22 Answers
May be your motherboard is defective or else cpu temperature is high. try to see it in the bios by pressing delete botton or F2 in the startup and goto to the hardware monitor.
Posted on Nov 16, 2009
Laptop will not start up
Try holding power button down for 10-15 seconds
Mar 02, 2015 | Computers & Internet
Sony grand wega randomly shuts off for about 15-30 seconds every 10 minutes. Fairly annoying
No lights?? Are all fans running properly? Check for dust buildup and clean out. Dust can slow down the fans enough to shut it down. Sounds like a cooling issue.
Oct 02, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
E Machine T3265 running Windows XP. was running fine until a few weeks ago. Starting turning off Windows (power stayed on) and rebooting on it own. Tried restoring system with restore disks. Kept shutting...
Hello friend,
> You CPU is not problem. ya may be you HDD create bade sector. Sec thing you change HDD data and power cable.
> You fresh new windows Install may be solve you problem.
> One time disconnect all cable attach in PC, and proper reconnect all cable. because if power connector lose then again you PC turn of auto.
More Technical Support call TechSupportMart.
Thanks...
Sep 03, 2013 | E-Machines eMachines Desktop PC
I cannot finalize my CD's on my Aiwa XC-RW700 Dual CD recorder might you know the problem? when I push the finalization button in blinks for a few seconds like it's going to finalize but...
On page 18 of >>>> the manual <<<< it says to press the " > " key within 3 seconds after "Finalize". You wouldn't want a careless button push to just run off and close out the disc, would you?
Aug 03, 2011 | Aiwa XC-RW700 2-Disc CD Recorder
When turning the system on, the fan comes on then accelerates to a higher than normal speed for about 10-15 seconds before shutting down again
check this things >>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......or better download repair guide...
click here to download repair guide
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
Projector turns off after 15 or so seconds of startup. The dell logo displays for those 15 or so seconds and roughly 1 second before it turns off, it projects a dialog box. It will shut off much faster if...
The problem you're describing is a classic symptom of a defective fan--some fans simply have + and - power connections. However, other fans have a third, yellow wire, for sending a pulse to the main board to tell it that the fan is indeed running. If the main board doesn't get the signal, it's internal programming instructions perform a shutdown in case of any error condition--protects the unit against excessive heat, current draw, etc. MAKE SURE THE DUST FILTER IS CLEAN! A dirty filter causes the fan to pull harder, increasing current draw, possibly triggering the symptom. The other possibility is a defective power supply causing an over-current condition. Again, the main board senses this and cues a shutdown. You'll need to send the unit out to a repair facility to confirm a diagnosis. Any reputable shop will give you a quote first with an explanation of the problem.
Sep 16, 2009 | Dell 3400MP Multimedia Projector
Sanyo PLC XU105 Will shut down in 10 to 15 seconds
YOU HAVE A BAD LAMP OR THE LAMP DRIVER BOARD BAD
Aug 24, 2009 | Televison & Video
No light Fan Runs CD Drive Runs ..But no Picture
Yes and no, are they both the same operating systems, usually the computer will search for the hard drive and reconfigure the setting and it may work, sometimes it will not reconfigure, just keeps running. Try it can not hurt anything will work or not.
Jul 27, 2008 | Gateway GT4010 (RBGT4010) PC Desktop
Compaq MP2800 Lamp powers down after a few seconds
Hi Wayne
It is normal for the lamp's fan to start running , but should actually happen within 15 seconds of starting up. Try changing the lamp's fan and if the problem still persists then you will have to replace the Ballast ( lamp's powersupply )
Mar 22, 2008 | Compaq MP2800 Multimedia Projector
Sudden shutdown / will not power up
try check your BIOS.Upon turning ON your laptop, press down the DEL button of your keyboard then check settings of your power.it maybe activated the standby mode by certain time.
Jan 17, 2008 | HP Pavilion ze2000 Notebook
Gateway GT4016 Desktop PC Logo
117 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
