Question about Samsung SYNC SGH-A707 Cellular Phone
See front display without opening phone. - Samsung SYNC SGH-A707 Cellular Phone
I guess you are asking how to see the front display while it is closed?
While looking at the phone, press and hold the button on the right. you can scroll with the volume control on the left.
Posted on Nov 19, 2009
How to open nokia n73's parts
In order to disassemble a Nokia N73 phone first of all you need to remove the battery cover (back cover) of the phone. Then remove the battery, memory card and the SIM card.
Pry up the front cover frame by using the safe open pry tool. It is recommended to start from either of the bottom corners of the phone. First insert the safe open pry tool between the cover and the keypad of the phone to unhook the clip underneath. Do not apply too much pressure as this may damage the front cover. You can use Triangle Safe Open Pry Tool in conjunction with Safe Open Pry Tool for prying up the cover frame safely and conveniently.
Do the same to unclip the clip from the other side. Once you have undone the clips, run the tool gently along the sides of the cover to unclip all the clips. This should remove the cover without much difficulty.
Now you need to remove the display shield which holds the LCD screen in place. You need to pry the display shield up using the safe open pry tool to unlock the clips holding it in place.
Once you have the display shield removed, the next step is to remove the LCD which will now be loose enough to be lifted up. Gently lift up the LCD using the safe open pry tool but be very careful as you still have to remove a ribbon cable to be able to free the LCD. To disconnect this cable you need to gently lift it and it will pop out.
Once you have disconnected the ribbon cable, the LCD can now be lifted up and removed. Your Nokia N73 is now disassembled.
Reverse the instructions above to reassemble your phone.
Please let me know if you need more assistance.
Regards.
Nov 03, 2011 | Nokia N73 Cellular Phone
WHEN OPENING-UP,THE SCREEN IS BECOMING ''BLUE'',THE CLOCK DISPLAYS THE TIME ON FRONT FACE.IT MAY RECEIVE INCOMING CALLS AND DIAL A NUMBER WITHOUT VIEWING IT.
The connecting cable from the IC board(Bottom Part) to the display(Top Part) is damaged at the hinged portion of your phone.Go to your nearest Sny Ericsson Service center to resolve this issue.
Feb 26, 2010 | Sony Ericsson Z310i Cellular Phone
My Verizon LG phone display doesn't work when I open the phone. The outside display says my messages are full, how can I delete my messages without seeing what I'm doing when I open my phone so I can get...
Data cable broken in your device.It connects the main board with the screen .If you dismantle the phone it will be by the hinge(where you open the flip top).
Jul 17, 2009 | Lands Phones
Front display stays dark after boot sequence
you must forget to re install the magnetic piece which located in the lower left corner of the lcd frame cover try to check it
Jun 18, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
The pictures that come with the phone, won't go away and I can't delete them.
You can not delete those pictures or the ATT logo unless you do two things....Either have it flashed. Or have it unlocked....then it will still display whatever companys sim you have in it.
The little green lock....its says: SYS, thats hardwired to the phones operating system.
Sorry this isnt a fixya but a youcantya
Jan 30, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Display
you need to replace the flexcable and lcd to correct the problem.....take the phone to a mobile service center to get it fx or a professional mobile tech.
Nov 11, 2007 | Motorola Mobility RAZR V3
Front Display not working on LG EnV VX9900
no i do not sorry best bet is to go to store
Oct 10, 2007 | LG enV VX9900 Cellular Phone
Siemens cl75 poppy phone
The Ribbon Cable that Sends the Data for the display Has a Crack in it,It happens over Time,,,, Time to Update your Phone....Sorry ttech
Jul 20, 2007 | Siemens CL75
Samsung SYNC SGH-A707 Cellular Phone Logo
59 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
