Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Craftsman 41A4315-7D. Door opens only 2 inches
I have a Craftsman 41A4315-7D. Door opens only 2 inches then stops. I've realigned the sensors (I think), unplugged (rebooted) the motor-I cant get the door to fully open. If I manually open it, I can then close it electronically. Any ideas?
  • hlacelle Nov 16, 2009
    Solution was right on-it's a broken spring. Any way someone can rough estimate the cost of repair?
    President:
  • 3,197 Answers
Check the door springs. One may be broken. You may have a bad drive gear which is a nylon gear just in front of the motor. Remove the cover and take a look. It will be obvious if it is stripped.
Posted on Nov 15, 2009
Testimonial: "Right on DonO It is a broken spring! Do you have a rough est of repair cost?"
  • 30 Answers
I looked around online, and it seems that the Safety Extension Springs (if that's the one that's broken) range from $25-$45, your best quess would be to contact your local Lowes or Home Depot.
Posted on Nov 16, 2009
Garage door moves few inches and stops, springs are fine, sensros are fine.
If it is not blinking when it stops, then the capacitor is blown. Replace the capacitor and it should resolve the problem.
Aug 09, 2014 | Craftsman Garage Door Opener 1/2 HP Chain...
My 1/2 hp sears craftsman garage door opener bought in 1992 has stopped working, The motor hums when the remote or wall button is pressed but the door will not move at all. Please help
Most common cause of the problem you describe is a bad start capacitor. Remove the cover from the motor unit. The capacitor is about 5 inches long and 2 inches in diameter.
Dec 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door only raises about two inches then stops.
Check the door springs and also remove the cover from the motor unit and check the drive gear. The door spring could be broken or the drive gear may be stripped.
The sensors only work when the door is closing.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
The opener won't close. My husband said the sensors need to be realigned. Did that and still the opener halts after 2 inches and flashes the light? It is a six year old Sears Craftsman Chamberlain model?...
If the main light flashes 10 times it is a door sensor problem. If the main light does not flash then you can try increasing the down force. This is a control on the rear of the motor unit near where all those white wires go. If this doesn't help you probably have a bad infra red sensor board. This is a small printed circuit board just in front of the motor.
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens only 6 inches and stuck
I would try jumping a wire across the white & red terminal to see if your safety sensors are working Properly! If your door opens you have a loose connection or faulty sensors.
Oct 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage door
sensor got bumped, realign till both lights show green
Mar 26, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,474 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
