Question about Honeywell Enviracaire Elite F300E-1019 Air Purifier
Ozone smell I cleaned the unit and now I am getting a very strong ozone smell.
  • Honeywell Master
  • 43,501 Answers
When the unit is clean it will produce more ozone. If the unit is a bit oversized then it becomes worse. As an installer I have to be carefull to not oversize these units. O3 is harmless and actually will only stay in the air as O3 for about 1/2 hour. Because of this it will not build up in the air. O3 also in a powerful disinfectant and will help kill mold and bacteria in the air. As soon as the filter gets a little bit of dust on it the O3 production will become much less. Run your fan continuously for a day or so and it will go away.
Posted on Nov 16, 2009
When I turn my brand new air purifier on on it smells like its burning or going to catch on fire is it supposed to?
That unit is a very heavy duty machine that uses ionization to clean air. There is a high voltage power supply that is used to generate ions. The unit can release ozone and that substance has a definite smell to it. If you have ever been near a copy machine or an electric motor that sparks, you would smell ozone. The concern is whether or not it is ozone. Ozone is regulated by the manufacturers to be held at a permissible level because at high concentrations it is an irritant and can cause respiratory issues by itself. The power unit for that air cleaner is on the top near the back and you can run the machine for a while to see if that area gets hot. That would be a bad sign. All the documentation is here: http://electronicaircleaners.com/f50f1032parts.aspx But if you don't trust the unit, take it or send it back.
Feb 20, 2016 | Honeywell (F50F1032) Air Purifier
Does not produce ozone, I have replaced the fuse, it has been cleaned and the amber light is not on.
it's possible that the ozone generator inside has gone bad. The only way to really know is to remove it from the unit and then test it with a power supply w/correct voltage of coarse. You will smell the ozone immediately if it works upon testing. (clean fresh smell) If it does need replaced, it's an easy fix for anyone with electronics knowledge. You will need to match up the numbers to get the correct replacement. Many are available on Ebay. Always disconnect the power to the unit before taking it apart. Hope this helps, Dave
Nov 18, 2013 | Ecoquest Living Air Classic Air Purifier
Hi-I have the Living Air XL. It's out for repair because I cannot smell the distinct clean smell it normally puts out. The repair guy just called and said it's fixed and running, but the green light bulb...
He probably cleaned the unit and restored the plaques. Green light or no green light, it doesn't affect the production of ozone. If still in doubt, when you go to pick it up, have him operate fit or you before you leave the store. I've had one 7years and the green light hasn't worked for three years. I clean it regularly and it still produces ozone when needed. Regular, routine maintenance is the answer.
Mar 28, 2011 | Ecoquest Living Air Classic Air Purifier
Running but does not have that clean air smell.
If the unit has not been cleaned regularly or recently, that is more than likely your problem. The interior is simply covered with dust. Clean the unit according to the Owners Manual instructions and you should be getting the ozone smell again. If the unit is more than 5 years old, you may need to also replace the plaques inside. These can be purchased online from the manufacturer.
Hope this helped to solve your problem.
Mar 09, 2011 | Ecoquest Flair Air Purifier
My flair unit does not smell of ozone. Why ??
It properly needs the filter and interior cleaned. Especially, if it has run a long time without being cleaned. Or there is nothing in the household air at this time to trip the Ozone producing switch.
Feb 06, 2011 | Ecoquest Flair Air Purifier
My Flair stopped working correctly,so I purchased new Ozone plates. It still doesn't provide that clean ozone smell. I took mine apart and cleaned it and noticed a small bulb inside that doesn't light up....
pull the unit out of the enclouser and check the bottom for a circuit board and on the board their is a glass fuse see if it is blown. Also on that same board their is a small round black fuse that is labled f21 it is a 400ma 250 volt fuse on my unit and is soildered in this fuse is just for the ozone
May 23, 2010 | Ecoquest Flair Air Purifier
My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Nov 14, 2009 | Alpine Air XL-15 Air Purifier
Ionic Breeze Repair
Ionic Breeze GP. Unit was working. Removed insert to clean. Now the unit will not turn on.
Jun 11, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Living Air XL-15 Classic - Foul odor!
Hi cant standit,
Can you control this odor by adjusting the ozone (O3) control? High levels of O3 smell obnoxious or irritating to some people; you want a fairly low concentration (~40 ppb - that's parts-per-Billion, not much).
It sounds like you've done everything else right. Have you consulted with the dealer you bought from? How about EcoQuest? If it's not the O3 level being too high, then perhaps there's something goofy with the unit. If it's under warranty, pursue that option. You should have contact infor with the unit; respond if you need it and I can post it.
Let me know.
Jun 06, 2008 | Ecoquest Living Air Classic Air Purifier
When ionizer is on even
Hi willy,
The ionizer itself shouldn't smell. I wonder if you're smelling O3 (aka ozone or activated oxygen), or if there's a short-circuit of some kind that is causing electrical components to overheat/burn. Burning electronics and singed hair smell more alike than ozone (which isn't the same as ionization, incidentally.
Write back with more details if you can, preferably with any details about your observations.
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 17, 2008 | Ecoquest Flair Air Purifier
Honeywell Enviracaire Elite F300E-1019 Air Purifier Logo
594 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
