Fuse/Relay Location*Fuse Amp Rating* Description
1 60A** PJB 2 30A** BSM 3 20A** Not used (Spare)
4 30A** Rear defrost 5 40A** ABS (pump)
6 60A** Delayed accessory circuit breaker
7 20A** Power point #2 8 — Not used 9 20A** Power point #1
10 30A** ABS module (valves) 11 40A** PTEC
12 50A** Ignition relay/Starter relay
13 40A** Trailer tow battery, Trailer tow turn signals
14 10A* Foglamps 15 15A* Memory (KAPWR)
16 15A* Headlamp switch 17 20A* 4x4 (v-batt 2)
18 20A* 4x4 (v-batt 1) 19 20A** High beam relay
20 30A** Electric brake 21 30A** Front wiper motor
22 20A** Autolamp; Low beam 23 30A** Ignition switch
24 20A* Rear Fog Lamps 25 – Not used
26 15A* Fuel pump 27 20A* Trailer tow lamps
28 20A* Horn relay 29 60A** PJB 30 20A** Rear wiper motor
31 — Not used 32 — Not used 33 30A** Auxiliary blower motor 34 30A** Power seats, Adjustable pedals
35 20A** Rear power point 36 40A** Blower motor
37 15A* A/C clutch relay/Transmission
Here's the rest. The would not fit in the original answer box...
38 15A* Coil on plug
39 15A* Injectors/Fuel pump relay
40 15A* PTEC power
41 15A* HEGO, VMV, CMS, PTEC
42 10A* Right low beam
43 10A* Left low beam
44 15A* Not used (Spare)
45 5A* Brake pressure switch
46 20A* High beams
47 — Horn relay
48 — Fuel pump relay
49 — High beam relay
50 — Fog lamp relay
51 — Police IVD relay
52 — A/C clutch relay
53 — Trailer tow right turn
54 — Trailer tow left turn
55 — Blower motor relay
56 — Starter relay
57 — PTEC relay
58 — Ignition relay
59 — Driver brake applied
60 — PCM diode
61 — A/C clutch diode
62 30A CB Delayed accessory
* Mini Fuses ** Maxi Cartridge Fuses
Wht is the PTCE Relay? Wht does it do or use for?
Do u guys hace the fuel pump circuit diagram for a '02 ford explorer?
