How do you take off the cover of my washing maching so I can put on a new belt?
    Brigadier General:
  • 4,088 Answers
If the rear panel is not removable with external screws, remove the top panel first, then remove the rear panel screws from inside and lift up to remove the panel. If the lower cabinet appears to be one piece, this may be a belt-less direct-drive type of machine in which the entire cabinet is removed after releasing the top. In these machines, it is common for the plastic coupling device to fail--remove the motor to replace the coupling. Hope this helps!
Posted on Nov 15, 2009
    President:
  • 2,702 Answers
It would be nice to know witch mechine it is? but,,,there should be screws in the top or down the sides at the back,,, the back may need to be removed to loop the new belt over the drum pully and then over the motor drive pully and the tensioner do unplug it from the water and mains first before working on it
  • Washing Mach... Master
  • 2,113 Answers
Most washing machines and driers have the top held down by a strong spring clip.  Try to pry the top off gently but firmly with a large screwdriver.  Be careful not to chip the powder paint.  The back of the unit may have an access panel that is easier to remove screws from.
My kenmore washer is completely drained but continues to run like a full load is inside. Can it be reset or what else can be done?
Allot of people try to keep their machs as long as possible ask yourself Is the mach worth fixing or get a new one. After several years they just wear out. And by the time u spend upwards of 2-3 hundred in parts and labor u could have put that money towards a new one, just to have a repairman look at the mach. is about 75$ and might even put that towards your bill., if the mach breaks down again after a repair, well you can see where this is going.
Jan 23, 2015 | Kenmore Washing Machines
Drum not rotating
Hi kokeri2156,
This is the common problem of loose or cracked belt,open the back cover of the washing machines,so you can access the belt take it out and replaced it with a new one with identical size,and put it back the belt. Feel free to ask whatever the results.
Regards; VOTIT
Dec 03, 2010 | Magic Chef Washing Machines
How to change the belt on a hotpoint wma54 washing machine
there is a rear access panel in the center of the back,remove this cover and put the new belt on the motor pulley,then over the larger drum pulley,it takes some strength unless you release the motor tensioner and retighten after the belt is on
Mar 23, 2010 | Hotpoint WMA54 Front Load Washer
How do i fit a belt to hotpoint washing machine WF865
*********** unplug from mains************** top cover off ....rear cover off ....remove old belt belt ...place new belt on lower puly feed it on to larg pull turn at same time ************WATCH YOUR FINGERS ********THEY CAN GET CAUGHT EASY******* done .put covers back on ...
Dec 30, 2009 | Hotpoint Ultima WF865 Front Load Washer
How to fit a belt to a wf440p washing maching
remove the top cover and lower rear cover. loop the belt over the motor shaft and then around the drum pulley, this will probably only go round halfway as it is tight, hold the belt to the pulley by turning it rather like putting on a bicycle chain.
when it's on make sure it runs centrally round the pulley adjusting the position on the motor shaft if needed.
Jan 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
How to put on the flat belt on hoover mach 5
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=681386
Generic problem for all Vacuums
How to put on the
Posted by jamescook76 on Jun 18, 2008
How to put on the flat belt on Hoover mach 5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are 2 to 4 screws on the bottom of the vacuum and then the top cover will come off in order to change the belt or the bottom plate will come off and then you can get @ the flat belt. It’s one or the other. A suggested flat belt change is recommended every 4 to 6 months for the best cleaning and to store the extra belts in a Ziploc bag in the refrigerator.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 18, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Removing motor to replace belt for agitator
first unplug washer then there are 4 half inch bolts on the motor holding it to the frame take those out unplug the motor harness. then twist it out you may have to take the hoses off. then there are 3 torxs screws in the pump take them out and put new belt on same way you took off and then reverse the steps and you will be ok
Jan 30, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washing maching belt replacement
some machines have stretch belts and are difficult to place, if you have the right belt for the model then its just persistence, believe me we as engineers have same trouble (if we are honest)
Sep 30, 2007 | Washing Machines
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Washing Machines Logo
Top Washing Machines Experts
