Question about Maytag MGR6875SS Gas Kitchen Range
My oven heats to temp set at but then cools down to 200, what is wrong with it? It is a gas oven.
5 Suggested Answers
SOURCE: MER57550AWAW electric - won't heat to selected preset temp
Any idea where to get parts numbers for this model? Maytag's website seems pretty useless. The model number does not even come up. BTW it should be 5750 in the title, not 57550
Posted on May 09, 2008
tzweeb
  • 318 Answers
SOURCE: After temp is set bottom oven will not heat up to desired temp
you probably have a burnt out or shorted out lower bake element in you r lower oven. it sometimes will actually break apart or look like it sparked thru the black tubular section. it is common and will cause no heat during the bake cycle.
you could try to do a broil and see if it gets hot and that would let you know the control is ok and just needs the lower bake element.
Posted on Jan 28, 2009
  • 464 Answers
SOURCE: Maytag Oven model MER5755QAS trouble heating up
your bake element could be burned out & the oven is trying to get to temp with the broil element only. see if it is getting warm or if it has a burnt spot on it. if it seems to be ok, you may have a bad oven sensor. the oven sensor should have a reading of at least 1100 ohms. let me know if i can be any further help.
Posted on Oct 13, 2009
marka19
  • 1430 Answers
SOURCE: Mer5755 Oven losses temp. Start at 400 loses temp later
The problem is usually the ignitor not reaching the correct amp draw .When the ignitor does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The ignitor are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the correct procedure for performing this test. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available.
Posted on Apr 02, 2010
Oven will not heat over 200
oven does not heat to desired temp we have used a oven thermometer and most of time oven is at 350 but thermometer is at 275 than up to 325 and then down again to 225
Jul 09, 2012 | Viking Professional VGRC365-4GD Stainless...
GE JGSP31GER Gas Oven doesn't heat up hot enough
The part your talking about used to run about $275 which is pretty high for a free standing range but the cost of it isn't important. The reason why is that they no longer make that part anymore and when i looked it up I got NLA which means no longer available. You may get lucky and find a company that possibly has one still in stock, but there is no way that it will come with a warranty, so if its a dud when you get it your stuck with it. I would invest my money in something I could fix when it came time to.
Jun 19, 2012 | GE Kitchen Ranges
Oven not heating up
Problem with oven sensor or control board (ERC). Oven sensor at room temperature should have resistance about 1080 Ohms, and it rises with temp rise.
Nov 26, 2009 | Kitchen Ranges
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Temperature is wrong
Many ranges show a beginning temperature that is higher than actual temperature, then the gap closes as it heats up.
Use a accurate oven thermometer to check your temps.
If it is faulty, it will not recalibrate to offset 200 degrees. You will have to replace the ERC.
Mar 20, 2009 | GE 24" Built-In Single Gas Wall Oven
Kenmore oven doesn't keep heat
im going to assume it is gas.. you may have a bad ignitor.. it is not gettin hot enough all the time to ignite the gas.. eventually it will not lite it at all..
Feb 15, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Gas oven not heating
waka,
I'm guessing that there is an issue of some kind with flow of heat inside the oven. Gas ovens use the hot air/gas exhaust to heat up the oven. Flames mean heat. The flames should be about half an inch long or so. If not, there may be an issue, but I don't think that is it.
Have you lined the oven with foil? It is possible that vents from the boiler section are closed up? That will prevent heat from reaching the oven.
Dec 03, 2007 | Whirlpool SF367 Gas Kitchen Range
Oven works when it feels like it.
The ignitor is weak and not lighting the oven consistently. Need to replace the ignitor.
Nov 16, 2007 | Amana RanARG7302 Gas Kitchen Range
My oven won't heat to temp properly...
All the ovens should be checked out at the factory. With that said it sounds like the thermocouple is bad or not installed correctly.
Apr 15, 2007 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Maytag MGR6875SS Gas Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
