Question about Sanyo Katana LX Cell Phone
My phone will not take charge. Do not know if problem is phone or battery
My LG cell phone won't charge?
You coulid have a bad battery in the phone. You may be able to borrow a battery from another lg phone that you know charges and then test if it charges with your charger. Also you might be able to take your battery and try it in another lg phone on a charger and see if it charges.
Aug 29, 2014 | LG Cell Phones
Will not charge battery
Two issues here as far as i know,
1) either the battery is old and died and hence doesnt charge.
2) the charger cable is bad or the adaptor is bad due to which the charging fails.
Solution
USe the same phone to another charger (borrowed from a friend or family member) and see if the phone charges. Or use the same battery in another (again borrow) device and charge the phone and see if it is working. you will know what the issue is. hope this helps.
Aug 21, 2013 | Cell Phones
My mini phone will not charge or switch on
First, the battery is drained, therefore any effort to turn it on will turn out abortive. Connect the charger to the phone and leave it for about 30 minutes to see if it will charge. If it does not charge then it means there is a problem.
The problem is most likely from either the charger, the battery or the phone. You need to diagnose each of them to know where the problem is from. To diagnose them you need to test them on other devices in order to know where the problem is from. First test the charger on another phone to know if it works. Then insert the battery into another phone and try to charge, remember the battery is drained and need some minutes to boost before indicating a charge, then finally, try another battery and charger to know if it will work.
Which ever does not work of the charger and battery need to be replaced, but for the phone, it is the connection port that need to be fixed if it does not work.
Thank you for using fixya
Caseytech
Jul 01, 2011 | Cell Phones
How I know my lg lsp 350t has full charged
When your lg lsp 350t is fully charged, it stops reading like it is charging. You can also turn off the phone and plug in the charger, once it is full, the battery meter will turn blue or show battery full. \but when the phone is on, the way you will know that it is fully charged is that the battery shows a full bar and does not charge anymore.
Hope this information helped.
Jan 14, 2011 | Cell Phones
Hi, I have buy nokia 5300 battery BL-5B on last week .but this battery have not standby long time ..I have charge battery morning and mobile have full charge battery 1 hour .then I call to mobile 1...
if you know how to use a multi tester try to check if your phone is shorted, put the range value to ohms x1 and top it to the positive and negative battery connection of the phone.
Oct 11, 2010 | Nokia 5300 Grey Cellular Phone
Battery works on another chocolate, but when inserted into this chocolate, it says it has no charge and powers down....is there something that can be done for the phone to recognize battery?
i am having a somewhat similar problem with my samsung gleam. so far all i did was pull out the "bad" battery and put a battery into that phone that i know was charged. when i did that, the phone worked. then i put the "bad battery" into my phone and turned it on. it immediately shut off. i plug in my car charger and nothing, no indication it was charging or anything. i take it home and plug in my wall charger to it and after half hour, charges fine. try swapping batteries and then charging in a phone you know will charge it, that is what i am getting at here.
Jul 20, 2009 | LG CHOCOLATE VX8500 Cellular Phone
My phones wont charge
clean out the contacts or get a new battery
Jul 07, 2009 | Motorola Mobility Moto Q
NO charge for the battery???
if battery has a charge then its charging --if not working when battery reattached then problem is with phone circuitry or plug connections
Jun 05, 2017 | Motorola Mobility MD41 for MD400 Series...
Battery not charging
Hi this problem is going to ba faulty battery i had the same problem after replacing the battery it was fine.
The problem was a couple of bad cells inside the battery but what your supposed to do to prolong the life of the battery is to let it go totally flat once a month i mean totally flat so it wont even light phone up then do full charge this keeps the cells good in the battery so remember to do this often should keep the battery lasting ages let me know if you need further assistance
Jan 22, 2008 | Nokia 3110 Cellular Phone
Charging problems
have you tried your dads battery in your phone it sounds like the battery is dead if your charger works on your dads phone then you know it not the charger the chances are it is the battery it would only be the phone if it has been dropped or got wet if this hasnt happened then the problem is the battery if your dads battery is the same then try charging his batt through your phone that way you would know if it was phone or battery.
If you take the phone into any phone shop they will test the phone and battery for free for you they can try the battery and also try a new battery in your phone and they will tell you if it is phone or battery but from my experiance it is going to be the battery let me know how you get on ok
Nov 27, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Sanyo Katana LX  Cell Phone Logo
55 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
