Question about Motorola Computers & Internet
What does it mean if the link light is out on the surfboard v 5222 digital voice modem?
  • Motorola Master
  • 32,281 Answers
The link LED on the LAN card and/or on the hub/router is switched on then it indicates that the communication between the the computer and hub/router is established and therefore data can transfer between computers, hun/router, Internet etc.
If the link LED light is out then the fault could be a faulty LAN cable or faulty LAN card in the computer or a faulty hub/router.
Posted on Nov 15, 2009
How do I reset my Surfboard modem SVB5222?
I have just viewed the manual for that unit and if you care to look on the back of that modem between the USB & Coax connector you should see a small hole. Use something like a small paperclip bent straight to press the small momentary switch. I personally would keep it depressed for about 15 to 20 seconds while the modem is on. If anything like other modems it should restart, bear in mind it may take some time to lock onto the signal.
http://www.arrisi.com/modems/datasheet/Voice%20Modem%20Replacement/Voice_Modem_Replacement_Battery_SBV5222_User%20Guide_English.pdf
Aug 08, 2014 | Arris Sbv5222 Surfboard Digital Voice...
How do i turn wifi off
Locate the Wireless LAN switch located on the front of your computer.
This could be located on the upper row on a laptop it will have the radiation look (((·)))
Make sure its pressed on or off whichever you need.
Move the switch to the right to turn on Wireless connections.
Right-click the network icon located on the system tray next to the clock.
You should see a list of available wireless networks.
Select the network you want to connect to and click "Dis Connect."
Motorola Surfboard Cable Modem User Guide
The user guide for your Motorola Surfboard cable modem can mean the difference between knowing how to locate and diagnose problems with your connection or staring angrily into a maze of blinking lights.
The user guide provides information on properly setting up your cable modem, understanding the indicator lights and troubleshooting problems before you have to call your Internet Service Provider.Connecting Your Modem
Your Motorola Surfboard cable modem must be connected to your home's coaxial cable connection.
Connect the coaxial cable from your cable outlet into the "Input" jack on your cable modem.
If your modem is wireless, it will connect to any computers and wireless devices in your home through the wireless signal sent from the modem.
Wired Internet connections require that you use an Ethernet cable to connect your cable modem to any supported computers and devices.
Understanding the Front Panel
The front panel of your modem is your key to understanding the status of your cable modem.
The front panel features "Power," "Send," "Receive," "Online" and "Link" lights, each of which displays information about your modem.
The "Power" button will display a solid green light when operating normally and will turn off when there is a problem with the power supply.
The "Send" and "Receive" lights will transmit a solid green or blue color when data is being normally transmitted through your modem and will blink when it the modem is scanning for an upstream or downstream connection.
A solid green "Online" light indicates that you are connected to your Internet Service Provider, while no light indicates that the Internet connection in your home is experiencing problems.
A yellow "Link" light indicates that a computer is connected to your modem with an Ethernet connection while a blue light indicates that a high-speed Ethernet connection is being utilized through the modem.
Configuring TCP/IP
The Transmission Control Protocol/Internet Protocol provides the basic foundation for establishing a local network and a connection to the Internet. The TCP/IP can be configured in the "Control Panel" of your Windows computer. Open the "Network and Sharing Center" from the control panel and double-click the "Manage network connections" option. Right-click the network connection displayed and select "Properties," then select Internet Protocol Version 4 and open the TCP/IP properties menu. Select "Obtain an IP address automatically" and "Obtain DNS Server address automatically" from the TCP/IP properties menu and click "Ok" to save your TCP/IP settings.
Troubleshooting
Many technical issues with your cable modem can be resolved by power cycling your modem and the computers and devices connected to it.
To power cycle your modem, unplug it from the power supply for 10 to 15 seconds and reconnect it to the power supply.
Restart all of your connected computers and devices while your modem is power cycling. Problems with the "Send" and "Receive" functions can be the result of a poor signal being sent to your cable modem. Tighten the coaxial cable connection to your modem and contact your internet service provider if problems persist.
http://www.motorola.com/staticfiles/Consumers/Products/Cable Modems and Gateways/SURFboard Cable Modem-SB6120/_Documents/Static Files/557621-001_SB6120_User Guide-US-EN.pdf
Nov 19, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
Wpa
Please don't submit multiple posts for the same request. It's nether clever nor helpful. Thank you
Jun 24, 2013 | Arris SURFboard SBV5220 Digital Voice...
FLASHING AMBER LINK IDICATOR LIGHT ON MY SB6121 MODEM
The SB6121 link light uses color to indicate the connection speed. Blinking means data transfer is taking place. Blue means that it's a 1000Base-T (High-speed Gigabit Ethernet). Amber means it's an older ethernet device. 100Base-T or 10Base-T Ethernet connection.
Nov 06, 2012 | Arris SB6121 SURFboard DOCSIS 3.0 eXtreme...
How to connect 2wire 2700 HG-B router to voice modem motorola
that 2wire only works with DSL services, if you are using cable internet then no it wont work. If the surfboard digital voice is just a VOIP router then yes, plug the surfboard into one of the ethernet ports on the back of the 2wire.
Jun 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
May 04, 2009 | Arris SURFboard SB5120 Modem
ONLINE light is off, power, receive and send are on.
Online Flashing - Scanning for a network connection.
On - Startup process complete. Modem aqcuired.
No online means no connection to the cable company DHCP server
Aug 12, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Installation cd
SURFboard® General Frequently Asked Questions ... your SURFboard cable modem are Ethernet and USB cables, power cord, an Installation Assistant CD ... Do Motorola SURFboard cable modems ... My SURFboard SB4220 or SB5100 cable modem
Click on the above link find the drivers you are wanting to down load or order on line.
Good Luck /Please dont for get to Vote.Thank You.
Dec 15, 2007 | Arris SURFboard SB4220 Modem
Computers & Internet Logo
1,330 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
