Question about Jenn-Air JGW8130DD Gas Single Oven
Temperature fluctuates too much - Jenn-Air JGW8130DD Gas Single Oven
  • 6,784 Answers
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Posted on Nov 15, 2009
How close should the temp control hold the temp
Generally the oven temperature will fluctuate as much as 30 degrees above or below the set temperature. The longer the oven is on, the less the temperature fluctuates. If you measure the highest and lowest temperatures readings with a thermometer after the oven has been preheated at least 20 minutes, you should come up with an average temperature somewhere within about 10 degrees of the set temperature. You can calibrate most ovens up to 35 degrees higher or lower if it is off. Any more than that requires replacing parts.
Apr 24, 2014 | GE Profile JTP18 Electric Single Oven
My oven wont heat up to the temperature i set it at. it's at least 50 degrees lower than what it should be, and the temp fluctuates anywhere from 20 to 50 degrees while it's on, even without opening the...
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 11, 2011 | GE Ovens
Oven temperature fluctuates.Oven heats to correct temp on preheat, but as the food cooks the temperature drops.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 17, 2010 | Frigidaire Ovens
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
I'm a landlord and my tenant's oven will not heat up to the proper temperature intermittently. I had a guy come out and test the oven and it works fine, yet my tenant is still complaining the oven is not...
Absolutely. That is the first thing I would think that would cause such a fluctuation of temperatures. BUT if it is a gas oven (WITH A PILOT FLAME) then FIRST consider the thermocouple needing to be changed. If the thermocouple keeps faulting it will shut off gas sporadically and keep the gas off until it resets temporarily on its own.
Mar 13, 2010 | Ovens
My GE gas oven temperature goes up and down a lot
The Thermostat on the oven might have to be replaced. This part is usually located behind the knob with the temperature settings. There is always a fluctuation in the temperature(usually 5% before the thermostat cuts the burner of and then back on. Other things can also influence oven temperature, like air drafts(usually caused by unrepaired or construction gaps in the wall on back of the range, but more often its the thermostat that need replacing. The following link can provide you with a further description of how the oven works: http://www.partsquik.com/appliancerepaircenter/Gasrange.htm I think you can also purchase your thermostat at that same site.
Jan 28, 2010 | GE Ovens
Kenmore Electric range does not maintain temperature setpoint.
How do you know the thermo sensor is working correctly when it gets hot?. No I think the thermal sensor is defective, it is cheap to buy.
May 04, 2017 | Kenmore Ovens
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Plz rate my solution
Thanks.
Dec 26, 2008 | Ovens
Creda oven
you might have already thought of this, buy an oven thermometer you can pop in the oven.
I bought one from my local cook shop
I have a the same cooker and similar problem - mine gets hotter by 50 degrees so I set the temperature 50 degrees lower than needed.
I noticed the problem a few years a go and luckily hasn't got any worse.
maria
Jan 02, 2008 | Ovens
Oven temperature
you guys should check your tempurature sensor. Our oven has been acting weird like saying it has heated up to 400 degrees in like 1 minute haha. Well after a few months of this happening on occasion we get an F2 error flashing..
did some research on it and apparently for GE ovens this is a temp sensor gone bad. Im looking to buy one now which is how i found this post, i just thought id tell you all what i found out and maybe you should look into that as well.
Oct 30, 2007 | Viking VGS0166 Stainless Steel Gas Single...
Jenn-Air JGW8130DD Gas Single Oven Logo
111 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
