Drum rotates. No Heat. Kenmore Electric Dryer 120/240V 28A 60Hz. MOD: 110.68932792.
Check the thermal fuse on the top of blower wheel housing,also while your there take off the cover of the housing and clean all the lint out,if your fuse was popped the lint buildup did it,check outside and make sure the air from dryer is blowing out and is not blocked,if it is blow out vent line if it's a long run with a leaf blower,if the thermal fuse is good read out the heater with a meter and if that's good read out the t-stats
Testimonial: "Bad heating element. Ordered replacement found on Internet."
Broken heating element was the problem. Volt meter indicated no continuity. Removed heating element and found a break in the coil. Part number was on bracket holding coil in place. Found replacement part on internet for $35 delivered.
