Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice maker freezes but doesn't eject the ice
Have whirlpool side by side model number fd2chqxkq
ice maker freezes but doesn't eject the ice
  • 11,896 Answers
Check that the shute and door is not frozen shut. You can check the power to and from the dispenser switch with an ohmmeter, test-light, or voltmeter to make sure it is not faulty. You can get parts and manual at repairclinic.com or partselect.com
This is the two most common problems for this problem.
Other than the dispenser motor itself which can become faulty. Check power to this as well.
Posted on Nov 15, 2009
We have a side by side whirlpool ice/water though the door water yes,but no ice production model number ED5SHAXMB10
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Aug 11, 2011 | Whirlpool Refrigerators
ICE MAKER DOES NOT DISPENCE ICE
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Electric GSH25JFX Side by Side...
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
imufo2
Leo Ponder
Jul 26, 2011 | General Refrigerators
On a frigidaire model frs26lh5ds1 side by side prost proof, the ice maker doesn't make ice. the water drips down into the tray and freezes there. any suggestions?
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Jul 26, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a sub zero model 650 refridgerator. It is making some ice then it seems as though the water keeps dripping and it freezes up the shelves. Its like the water doesn't shut off when its suppose to...
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Refrigerators
Ice maker has stopped working.
Leo Ponder
Jul 01, 2011 | Whirlpool Ice maker 4317943
Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice Maker not working
Get me the model number. Put tap water in ice maker tray and make sure arm is down. Let it freeze. Wait and see if the ice will drop, this should allow water to come into the ice maker for another run. Let me know, Thanks, Sea Breeze
Apr 27, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice machine freezes up
Is the ice freezing on the surface of the tongs? You may be pulling in moist air from the outside of the fridge.. check all the door seals to make sure no air is getting in. What is the model number of the unit so I can pull up a diagram?
Dec 27, 2006 | Maytag 22.6 cu. ft. Side-By-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
160 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
