Question about Lexmark X7170 All-In-One InkJet Printer
Error message 2200, unpluged and still no print
  • 320 Answers
When you unplug this remove the power supply completly then give it a minute then reinstall power the unit on. if this doesnt do it us the belt to move the scanner carriage to the middle then power the unit on see if this fixes it. if not you may need to remove the top and clean the scanner mirrors. there is a carriage home strip on the underside of the top that reflects the light back to a photo cell to say the carriage is home. anything that dimms this light will cause it not to see home.
Posted on Nov 16, 2009
Problem in canon copier.i hv got an error message E000002-0000. can u tell me the solution
Sounds like a power problem.
Google the error code and you will find many possible solutions as there are too many to list here.
Jan 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
I need a hard disk drive for a cannon 2200 imagerunner the copier keeps showing a error message
If you have a Service Contract with the local CANON office, call them, and get them to make a service-call to fix your printer.
Jul 17, 2010 | Canon (6981A002AA) for imagerunner 2200,...
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
HP Laserjet 2200dn print spooler unable to connect
Have you tried a different driver eg. rpcs or another version of pcl?Have you checked your workstations services app to check if your print spooler is running?Also when you print a config page from the hp it will give you your network details.To eliminate your network grap a crossover cable and connect directly to the printer and test.Let me know.
May 22, 2009 | HP LaserJet 2200dn Printer
Error message on Cannon IR 3300
that is a stack delivery error could be one of the motors or a board do you have the internal finisher or external
Jan 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Problem printing PDF document
In Print settings if using PCL select Print as Image. Also Spool Printing. Use PCL5e or PS drivers.
Oct 23, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Error code E00003-0000
The film (plastic) film is probably torn from a piece of paper that got jammed between the upper and lower section causing an overtemp lockout condition.
1. Remove left paper door.
2. Remove conector rear plastic(black) and fuser shields(2) screws holding fuser cover shield and unplug (3)connectors,2on the rear and a small one on the front lower right of fuser unit
3. Remove (2) assemlbly mounting screws one at rear and one
on the front sides.
4. remove unit and purchase new complete unit from cannon
5.Installed new fuser by reversing above steps.
May 28, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Solution
hai, its a fixing moter problem ,replace the fixing motor
May 23, 2008 | Canon (6981A002AA) for imagerunner 2200,...
ImageRunner 3570 cannot scan
Do you have a "Board Scanner"? It's Option, you must buy it.
Mar 19, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Lexmark X7170 All-In-One InkJet Printer Logo
105 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
