Question about Moen & One Handle Tub & Shower Faucet
REMOVING CARTRIDGE IN MODELL82694 - Moen & One Handle Tub & Shower Faucet
  • 8,197 Answers
Go to this link it will help you.
http://www.moen.com/shared/pdf/l82691pt.pdf
Posted on Nov 15, 2009
HOW DO I INSTALL INK
Sir/Madam
Tell Me Your HP Printer Model Or You Can Perform These Below Step To Change HP Printer Ink cartridge,
Step 1: Open the printer
Turn on the printer. Press the Power button if it is not lit.
Open the printer cover, then wait until the print cartridge cradle moves to the right side of the printer and is idle and silent.
Figure 1: Raise the cover
Step 2 - Remove old cartridges
1 Press down lightly on top of the cartridge latch.
2 Pull out the bottom of the latch to unhook it.
3 Slide the cartridge out.
Step three: Use a cartridge protector
If you are temporarily removing a working cartridge (for instance, removing a Black cartridge in order to install a Photo cartridge), put it in a cartridge protector. Cartridge protectors come with Photo cartridges.
4100022b-6f18-428e-a2bc-bbd00a59c50f.gif 12806acc-4ccc-4074-b41c-6ca5d04702b4.gif
Step 4 - Make sure the new cartridges are compatible
Step 5 - Install the new cartridges
Figure 6: Remove the protective tape
Figure 7: Contacts and nozzles
1 - Contacts
2 - Nozzles
Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
Cartridges marked with a triangle go into the left carriage slot.
Cartridges marked with a square or pentagon go into the right carriage slot.
Figure 8: Put each cartridge into the proper slot
3 Push down on the print cartridge latch until it snaps closed.
5e2afb9d-cef4-415d-bd5c-a6c08dc7a1c6.gif acbe1f2c-5f74-4596-9d01-84173e86e0c8.gif
4 Close the printer cover.
Print cartridge maintenance
After removing the print cartridges from the printer, it is necessary to follow basic care and maintenance guidelines to keep them from drying out. The following guidelines will help maintain HP inkjet print cartridges and ensure consistent print quality.
Do not reattach the plastic tape that covered the ink nozzles since this can damage the nozzles.
Store the print cartridge(s) in a print cartridge protector or airtight plastic container. If the cartridge is stored in an airtight plastic container, make sure the nozzles face down and are not in contact with the container. Do not use plastic bags: this may damage the print cartridges.
Placing a moist paper towel in the airtight container may help to keep the cartridges from drying out.
A print cartridge protector is provided with the photo print cartridge.
To insert the cartridge into this protector, slide the cartridge at a slight angle into the protector and snap it securely in place.
To remove the cartridge, press down and back on the top of the protector to release the cartridge. Slide the cartridge out of the protector.
Do not drop the print cartridge since it could be damaged.
In case You still Having Problem Then I suggest You Visit HP Printer Official Website
Removing and Installing Print Cartridges
Or
still Having Problem Then Follow Us On:
HP Printer Support
Feb 13, 2014 | HP PhotoSmart Office Equipment & Supplies
Stuck cartridge
Best thing I can recommend is to take it in for service. If you would rather risk breaking the printer you could try removing the cartridge forcefully with a pair of pliers. If you have some experience with removing covers on electronics, and you have screwdriver bits to match the screws, you could dismantle the case until you can reach the area where the cartridge is stuck and dislodge it directly, again risking damage, but if you take your time and don't apply too much force you may succeed.
Nov 10, 2013 | Dell 2135cn All-In-One Laser Printer
Jam cartrige Area
Clear jams from the print-cartridge area
1. Open the print-cartridge door, and remove the print cartridge.
Figure 18: removing print cartridge
2. With both hands, grasp the side of the media that is most visible (this includes the middle), and carefully pull it free from the product.
Figure 19: removing jammed media
3. Replace the print cartridge and close the print-cartridge door.
Figure 20: reinstalling the print cartridge
For any other Jam types Visit the following link : HP Lasterjet M1522
Regards,
Shrey
May 30, 2011 | HP LaserJet M1522nf Multifunction Printer...
I HAVE PLACED MY BLACK CARTRIDGE IN THE COLOUR SLOT AND IT IS STUCK HOW CSN I GET IT OUT
You may have damaged the Cartridge cradle already, but removing it may also damage the Cartridge cradle. First, inspect the cartridge to make sure there are no plastic clips, etc. blocking the passageway for removing the cartridge. It may take some force, but the cartridge should slide right out. Most HP printer cartridges are similar, if not the same size and shape, so it should come out with ease. You may need to use a flathead screwdriver, taking caution to not break the Cartridge cradle any more than it already may be.
Mar 12, 2011 | HP Office Equipment & Supplies
How to install new cartridge
Make sure the printer is on and not printing. Have a new cartridge handy, as this installation should be done in one session.
Note if the "cartridge is low" or the "cartridge is empty" light is activated on the printer and follow the specific instructions carefully in the document below for each situation.
See "Removing and Installing Ink Cartridges" in the following document:
Epson Stylus Photo R300 - Removing and Installing Cartridges
Mar 01, 2010 | Epson Stylus Photo R300 InkJet Printer
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
Cannot remove old cartridge
steps for removing and replacing the toner cartridges:
-before removing the toner cartridges, disconnect the A/C power cable from the back of the system & remove the printer's top cover
-rotate the securing lever upward to unlock the toner cartridge
-lift the cartridge out of the chassis, each toner housing and cartridge is color-coded and labeled for easy identification of toner cartridge color locations
-just reverse the previous steps to replace the toner cartridges
Jul 09, 2009 | Dell 5110cn Laser Printer
Lostmanuaellexmarkx5070printerneedtochangeincartage
Removing a used print cartridge
Make sure the printer is on.
2 Pull the control panel up.
3 Raise the cartridge access door.
The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
4 Press down on the cartridge carrier latch to raise the cartridge carrier lid.
5 Remove the used print cartridge.
Note: If you are removing both cartridges, repeat steps 4 and 5 for the second cartridge.
If this helps you plz rate this. Thank you kindly.
Jan 30, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
Mp 460 tryin to insert ink for the 1st time
Your post is in the wrong place. I almost got you the wrong directions. LOL
Issue: How do I install the ink cartridge(s)?
Solution: Installing / removing ink cartridges MP160 / MP180 / MP460
Installing / Removing Ink Cartridges To print normally, install or remove ink cartridges in an orderly procedure. Installing ink cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
Nov 12, 2007 | Brother HL-2040 Laser Printer
Moen & One Handle Tub & Shower Faucet  Logo
143 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
