Question about Frymaster Dean EH1721 Deep Fryer
I have a Frymaster EH1721 deep fryer and it is beeping and the temp screen says HELP. What is the problem?
  • 612 Answers
Your drain valve is either open or you may need a new Drain Valve Micro-switch: The computer will display “HELP” when the drain valve is opened. The computer will lockout and prevent any cooking operation until drain valve is closed.
Try this first. The computer will display “HELP” when the drain valve is opened. The computer will lockout and prevent any cooking operation until “EXIT/COOL FILTER” is pressed. So press Exit/Cool Filter and see if it resets. If not and your red drain handle is closed all the way, you will need to replace the Drain Valve micro switch.
If you need anymore info on this unit, don't hesitate to respond back and I'll be glad to try and help. Good luck
Posted on Dec 09, 2009
My fryer heat up to 285 then quit then try to light but want,
sounds like the high limit is doing what it is suppose to do. Check the actual temperature of grease with a perometer and see if it matches temp on computer if it is more than 10 degrees off or fluxuates irraticly change the temp probe. If it is dead on change the high limit.
Jun 25, 2011 | Frymaster Dean 2424G Deep Fryer
How do u program a new button for time? We have been introduced a new item that only needs to cook for 1 min & 30 seconds & were not sure how to do this. Model # SCFD350GNCS Serial # 0904TS0005
It will depend on which computer configuration you have on your fryers.
You can download this manual from frymaster to help, it contains all programming instructions, just find the computer/controller you have and follow the steps.
Computers Operation Manual from Frymaster.com
Jun 08, 2011 | Frymaster Dean Frymaster/Dean FPEL3 Deep...
It keeps beeping and saying help
check the ignition system.controller will display help when burners do not respond during heat start-up or heat demands.also check if the unit receives sufficient fuel for ignition.
Mar 29, 2011 | Frymaster Dean FPH55-2 Deep Fryer
Hi, Frymaster electric fryer. When unit is turned on the right display shows "prob" and it beeps
There is a problem in the system. The problem is usually a sensor that is not reading correctly or not working right.
To troubleshoot this type of problem it is best to call the factory tech. support people and have them walk you through the troubleshooting. then they can also guide you to getting the proper replacement parts. For a problem that is showing up like that you will need OEM parts anyway.
heatman101
Dec 09, 2010 | Frymaster Dean FM345EETC Deep Fryer
My frymaster eh1721 cycles the mercury contactor every three seconds upon turning it on. What could be the problem
The metal coil that is very close to the mercury switch is worn out and weak after many times of use.
Oct 17, 2010 | Frymaster Dean EH1721 Deep Fryer
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
My Frymaster is beeping and coming up with a message HOT on the screen
Temp got to hot and shut down high limit. Also check for a broken wire to high limit
Sep 17, 2009 | Frymaster Dean H22 Deep Fryer
Dean gas deep fryer m# SR142GN
Thermocouple is getting weak. Replace the thermocouple with a new part.
Apr 21, 2009 | Frymaster Dean 2424G Deep Fryer
Prob code
THIS SOUNDS LIKE A THERMASTAT PROBLEM!
Dec 08, 2008 | Frymaster Dean EH1721 Deep Fryer
Frymaster Dean EH1721 Deep Fryer Logo
95 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
