Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I have a bad_pool_caller erroron boot up Running windows XP pro - Still on SP2 Bad_pool_caller error 0x000000c2 (0x00000050 0xe2fbf000 0x00001fbf 0x16400000) suggestions?
    Problem Solver:
  • 11 Answers
1st. :
Remove any and all overclocking from BIOS ! You can use Load Default Settings.
2nd. :
Download MemTest, burn it on another computer - test your RAM ( I preffer memtest86+ , first link)
http://www.memtest.org/#downiso
http://www.memtest86.com/download.html
If problems found, change your RAM modules
Then :
Try :
Safe mode with networking ( F8 on boot )
- System restore to previous date without the error, remove any software with 3rd party hardware drivers, roll back driver updates.
Read and follow this :
http://support.microsoft.com/kb/820765
Posted on Nov 20, 2009
Error bigpipe win xp professional sp2
This is due to a security flaw in SP2. You will need to download SP3 update from Microsoft!
IF you go to Microsoft XP SP3 Manual Update, follow this link and download the update then run it. This will correct the issue.
I also suggest that turn on automatic updates. Although XP is no longer supported by Microsoft you will still get all the old updates.
Oct 16, 2013 | Microsoft Windows XP Pro W/MUI SP2...
ASUS M4N68TM 1TB hitachi HDS721010C SATA Drive 460gb partition Phenom II X2 Trying to load Windows XP Pro For a client of mine. Windows trys to install but after the format partition part it reboots then...
What Service pack of Windows XP are you using? A 1TB drive will require SP2 or 3. Also, does this board require "AHCI" drivers (hitting F6) to install special boot time driver.
It sounds like a boot time driver. The other option is that there are bad blocks on the drive. That will do the same thing. However, check into boot time drivers, Visit http://support.asus.com look up this motherboard and see if there is a "SATA driver" required .
Jan 07, 2011 | ASUS M4N68TM Motherboard
My WDBAAU0015HBK external harddrive don't boot when i start up my computer. It says initalising USB divices and then when it autodetect the USB mass storage devices it stops. In the BIOS i put the boot...
It sounds like the BIOS is set to auto-boot from the USB device.
Have you reset the 'boot order' in the BIOS?
Also if you are still running sp2 go to Microsoft update and install the updates. You should be running on service pack 3.
(the updates are free, and are more secure than sp2)
Jul 20, 2010 | Computers & Internet
My acer aspire 5310 gives blue death screen (Bad pool caller) plus it does not detect the hard drive
If you are getting a blue screen in your Windows operating system that says something about a bad pool caller, you are in for a tough ride. The bad pool caller error means that some piece of software somewhere on your computer has done something wrong. For this reason it is important to write down the error codes that you receive with this message to help in determining what exactly is going on.If you have successfully been able to record these error codes in some way and have access to a computer that is working, the best place to start is on the Microsoft website. Once you get to their website, try entering the error codes that you have written down to see if they can give you more detailed information about the software that is causing the problem and any possible solutions to correct the issue.If you have not been able to find a solution to your bad pool caller error using the above method, then there are a few things that you can try. Often a hardware device can also cause problems that result in the bad pool caller error message, especially USB devices. Start by removing all of your peripherals including printers, scanners, external modems, USB hubs, etc. if you do not receive the error message once you have done this, then add one device back at a time, until you find the source of your problem. If this works and you know what device was causing the issue, you can try reinstalling the software for that device or replacing the USB cable that is connected to that device to see if that will solve the problem. If the problem still persists, it would be a good idea to run MemTest86, which can be downloaded online, to test your RAM for errors. A bad hard drive can also result in bad pool caller messages.If you have recently purchased your computer or have warranty on your computer, perhaps the easiest way to deal with this difficult problem is to take it back to them. Because of the nature of a bad pool caller message, which can be caused by almost anything, it is easier to have them deal with it rather than trying to isolate and correct the issue on your own.If you have built your own computer or are working on an older computer that no longer has a warranty, then you may also be able to get some clues into what is causing the problem by looking through the Windows Event Viewer for error messages or information. If you do not know how to do this, then a quick search online will explain how things are logged in the Event Viewer and how to interpret the information provided.Finally if all else fails and you are sure the problem is not related to a peripheral or other hardware device, then you can reload the Windows operating system on your computer. This can be done without losing your personal data and files, but be sure that you perform a complete backup before attempting this step just in case. There are the odd situations in which a bad pool caller error will occur during the installation of Windows in which case you will need to try and completely reformat your hard drive and start from scratch.
Apr 20, 2009 | Microsoft Windows 2000 Professional for PC
Can't repair bootsector in XP PRO
You can try this, with the pc running, open case,touch the metal case with one hand and the other hand unplug the drive. Now shut down
the system,unplug the system and hit the power button until the lights die. Plug in the drive and reboot the pc, go into bios and go to
boot. Check to see the drive is listed boot order. reboot and see if it boots.
If you can get into user account you can set admin password, then try restore cd then run fixmbr in dos.
If you can, get HDD Regenerator, and you can check the drive for errors, them run it again and repair them if possible.
But no, most of the time something causes the file to corrupt and lose boot not a bad sector on the hard drive.
Apr 07, 2009 | Microsoft Windows XP Professional SP2 for...
Windows setup fatal error
This can be caused by errors on the CD-ROM media, or by a bad CD-ROM drive. Try using a different CD-ROM drive if you have one.
Mar 11, 2009 | Microsoft Windows XP Professional SP2
Xp sp2
no isn't virus
i advice you to clean you Ram
and change you cd xp2
Jan 26, 2009 | Microsoft Windows Xp Home Edition Sp2...
Explorer.exe Application error in Windows XP Professional SP2
This could be a memory problem or a problem with the OS (XP). If you can boot the original XP CD like your doing an install then it's not a memory problem more the likely. Can you boot your XP CD?
Nov 27, 2008 | Microsoft Windows XP Professional
Cannot install windows xp
sounds like a bad usb device or memory. try eliminating unnecessary things.
Nov 07, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
118 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
