Question about Baumatic 23 in. BDW9 Built-in Dishwasher
Right hand side nylon spring cord guide broken when cord snapped and now door return has no tension.
Searched for a nylon rope guide for a Baumatic BDW 9 but was unable to locate one. I found that many of the components for the BDW 9 also fitted the BDW 10. So I searched for the rope guide for a BDW 10 and found the correct product. Problem solved!
Posted on Nov 18, 2009
Spring on door does not hold door up
The doors have a combination of nylon cord and spring that works through a pulley system and could be the nylon cord or spring. You need to remove the side panel to repair this.
Oct 15, 2013 | LG Dishwashers
The carriage of my typewriter isn't moving. I can move it manually but it doesn't do it automatically when i type, or press the space or tab buttons.
Does it feel like there is some spring tension pulling the carriage to the left? If not the drawband or main spring is probably broken and will need to be replaced. If you move the carriage all the way to the right, you should be able to see the main spring housing under where the carriage was. You should be able to rotate it by pushing it towards the left unless the cord is still attached. If the cord isn't attached you will be able to see where it should attach to the housing. There will be a notch. The cord goes under the carriage and attaches under the carriage on the right side on a little post that stick down. If the cord is broken or missing you can use a strong little cotton cord or heavy nylon (fishing) line.
Apr 13, 2013 | Brother Office Equipment & Supplies
The door on my beko dishwasher now just drops open ,how can I fix this please
The spring or nylon cord attached to door hinge has probably snapped. take side off both sides for simple fix. if not then the plastic catch at top of door is probably not engageing correctly. good luck
Apr 13, 2011 | Beko 24 in. D3421F Free-standing...
Door falls open
The side spring springs could have unhooked. Some springs connect to a nylon rope that slides over a plastic guide. The rope could also have snaped or slipped off the guide. You need to open the sides (normaly the back first) to check. This is easy to fix if you have the right tools...
May 11, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
How to replace drive belt on john deere model 345
- remove deck
- remove seat and rear fenders
- pry off deck adjusting knob
- remove F/R pedals
- remove floor plate
- use jackstands to prop up entire right side of tractor
- remove (2) screws holding fuel lines on side of frame
- lift out gas tank, set alongside left side of tractor
- remove plastic fan from hydrostat
- disconnect the electrical connector for the electric clutch
- from the top-side - use a 3/8" drive rachet - stick it into the tensioner slot next to the idler, rotate it to take tension off the belt, and remove belt off hydrostat pulley
- from underside - remove front idler (next to electric clutch)
- from underside - remove the "right-most" idler off the spring tensioner
- from underside - remove the "left-most" idler off the spring tensioner
- now the tensioner can rotate fully to take almost all the tension off the extension spring
- pop the spring off the tensioner arm
- the belt should now be able to be removed from the machine
- reinstall in the opposite fashion
- note: to reattach the spring, connect a nylon cord to the spring, and pull it rearward and guide it onto the tensioner arm - you need to stretch it about 1"
- for reattaching the two idler pulleys to the tensioner, get someone to hold the ratchet so the tensioner is positioned for the belt being in it's most-loose position. You may need to wrap the new belt around the hydrostat pulley first, and assemble the last idler pulley and belt at the same time to complete the procedure.
Apr 20, 2010 | Garden
My garage door opener only opens the door 2 feet high and stops, what could be the problem?
You could have a broken door spring or the drive gear is going bad. You need to remove the cover to check the gear. It is white nylon and is just in front of the motor. You can also increase the 'up force' which is a control on the rear of the motor unit.
Oct 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
KitchenAid KUDS01FL - door spring tensioner snapped - how do I fix / get parts?
Replaced the tension spring cords. The plastic portion of the cords had broken. I think this is desined to fail since it is such light plastic.
Aug 14, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
WHEN OPENING THE DISHWASHER DOOR, IT DROPS QUICKLY.
Actually I found out that for a LG dishwasher it is as likely to be the cable/cord attached to the spring and door. This a very odd setup in that this cable is made of nylon cord, and not any thicker than a round shoelace! It clearly should be metal cable, and it's not that hard to replace the nylon stuff with steel. Anyway, it is worth it to pull the unit out and open the side panel to see if in facts it's a broken cord or spring first before ordering any parts.
Dec 04, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Broken door spring on kitchenaid dishwasher
kitchenaid should be made to recall all of these dishwashers that have that string holding door since it could pose a hazzard to children. They should be made to put in a metal cable at no cost to the consumer
Jan 12, 2008 | Dishwashers
Baumatic 23 in. BDW9 Built-in Dishwasher Logo
166 people viewed this question
Top Baumatic Dishwashers Experts
Greg Cann
Greg Cann
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
