Question about Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi ZJD1219 Washer/Dryer - noisy spin and dirty spots
Zanussi ZJD1219 Washer/Dryer - making a terrible noise when on spin cycle and clothes coming out with dirty spots on them......have tried putting on 95 wash cycle with no soap and also same again without soap - this has not helped.........
  • Zanussi Master
  • 3,463 Answers
Sounds like the main drum bearings have failed, and the marks on clothes are probably grease spots from the main bearings.
It is quite an involved repair, and not one that I would recommend you tackle yourself unless you are competent to do so,as it really is involved.
Please rate my solution.
Thanks.
Posted on Nov 15, 2009
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Drum noisy when in high speed spin
Problem for Zanussi ZJD1219 Front Load All-in-One Washer / Dryer How do i change the main bearing please?
Feb 02, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
After wash clothes come out after wash they have dirty specs
if machine is noisy in spin cycle suspect faulty bearing seal. replace seal and bearings
Jun 30, 2009 | Zanussi IZ12 Front Load Washer
Zanussi ZJD1219 Not Drying
check safety overheat button due to faulty stat or blocked vent,burnt element connections,blown element hope this helps
Apr 07, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Error E20 showing ........stops during wash cycle and clothes not dry on drying cycle
not familar with the code but usually wash has a built in thermo stop to wait for water to heat to correct temp,if it works normally in a rince cycle and spins out and finishes properly i would look at heat element or stat,hope this helps
Apr 06, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Rubbing and Clicking Noise in Dryer.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Mar 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Zanussi Model FLA 1002W Washing m/c.
my w.m. is very noisy, after cycle laundry is with black spots on and white bits on clothing but it is not tissues. ?
Feb 13, 2009 | Zanussi FLA1101W Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Drum noisy when spinning
main wash bearing fail parts for this £48 if you are mechanicaly minded then its a 3hr job if you have all the tools appliance doctor
Jan 28, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
Zanussi ZJD1219 Front Load Washer / Dryer Logo
525 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
