Question about E-Machines T5048 (7136) PC Desktop
Not reading wireless connection - E-Machines T5048 (7136) PC Desktop
  • E-Machines Master
  • 32,281 Answers
The wireless router needs its wireless settings configured and also the wireless card in all the laptops and or computers needs to be configured with the router’s wireless settings so the laptops and desktop computers can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Posted on Nov 15, 2009
How to connect brother hl5470 using wireless
Brother hl5470dw only requires a Wireless connection, SSID and password to connect up to a computer, not AOSS.
Read the network set up manual here
http://download.brother.com/welcome/doc002930/cv_hl5450dn_eng_net.pdf
Apr 09, 2014 | NetGear N750 Wireless Dual Band Gigabit...
I can not connect my laptop wirelessly
What is the operating system on your laptop?
If your network is secured then you will need the setting of the router.
Is there any other wireless computer which can connect?
What error message do you get?
Read more about wireless network connections
Jun 21, 2012 | NetGear WNR2000 Wireless Router
Belkin f5d8235 unidentified network
Does it ask you for the wireless security password while connecting?
I think you can try creating a new wireless network on the router and see if that works.
What is the operating system on your computer?
How many wireless computers do you have?
Read information about wireless network connection on windows computer
Jun 14, 2012 | Belkin (F5D8235-4) Wireless Router
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
Cant connect to secured wireless network...
Hi Grant,
If it says aquiring acquiring network connection while you connect to the wireless network it means that something is conflicting with the wirelss network, so first you have to check wether 2 wireless utiliies ( windows wireless utility and dell utility )are active at the same moment, if yes disable one of them and try again, still if it does not connect, disable antivirus and firewall and check if that fixes the issue, still if it does not work then try changing the security type on the routers page, basically this should work out and still if u have any issue, please reply to this msg for further troubleshooting steps....
And even if it gets resolved please reply once.
Thanks and Regards
Anup
Apr 01, 2009 | Dell Wireless 2350 Router
Wireless controller wont connect to console
lightly adjust the USB in the system with it on and keep pressing the home button
Chris
Jan 12, 2009 | Intec PlayStation 3 Infinite Play Wireless...
Unable to connect to the Internet
Check to see if your wireless card is displayed under “Network Adaptors” in “Device Manager”. You can access the "Device Manager" by going to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column. If it is detected and there are no alerts or errors, try uninstalling the wi-fi card, reboot the laptop and reinstall the drivers.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 04, 2008 | Dell Inspiron 5100 Wireless Mini-pci...
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
E-Machines T5048 (7136) PC Desktop Logo
192 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
