Question about Maytag Atlantis MAV8551 Top Load Washer
The washer doesn't spin in the regular cycle even though the dial says off
    Brigadier General:
  • 3,513 Answers
The most likely the problem with your washer is a bad timer.
The part number for the timer AP250048
Here are the break down diagrams for the Maytag washer :
http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=872032&&model_id=26556#d872032
Thanks for contacting Fixya.com
Posted on Nov 15, 2009
Washer won't spin or drain
My bet would be that the timer got damaged as a result of someone rotating it backwards to rejigger the wash cycle.
Jun 04, 2016 | Whirlpool Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Aug 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
Washer runs when timer dial turned though ON button not pushed
Problem solved by ourselves! It was NOT in the circuit board (brain) of the machine. It was NOT in the door locking assembly as others would lead us to believe. It WAS the on/off switch on the control panel--part number 22002560 - a $22.00 problem fix.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
Neff 5644 - how does it work!??
"e" is economy - ignore this there is a selection of spin speed - most people use the fastest half load is what it says - most people wash a full load so ignore the temp dial just selects wash temp. for normal washes set to 40deg can't remember the symbols on program dial but think they are fairly self-explanatory this machine is just a washer remember to check the filter regularly
Jun 14, 2007 | Neff W5340X0 Washer
Maytag Atlantis MAV8551 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
