Question about Bamix Mono Hand Blender - Black Single-Speed Handheld Blender
I am unable to remove the blade, what can I do
    President:
  • 2,702 Answers
The blade is a screw fit on the shaft of the blender,, if you only use one blade just rince the blade under the tap and dry it off before putting it away, the only way to un-screw the blade if its stuck is give it a sudden jolt on the side of the blade with a soft hammer in the same way as it turns,,this may shake it lose,,,not to hard though,,,
Posted on Nov 15, 2009
  • jssgrl May 23, 2014
    I usually take a blade screwdriver and gently pry it off to the point where I can remove it by hand.
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
How do I put the blade on my Ostis PowerMax clippers? I have tried with it on and off with no success. Thank you.
The blade release should be under the heel of the blade, just below where the blade tongue hinges. You normally only need to press it when removing the blade, when snapping the blade shut it is mostly not necessary to push it. They are a bit like a door latch that self lock when closing.
Feb 17, 2015 | Oster PowerMax 2-Speed Clipper Kit
Kitchenaide blender pitcher blade assembly sticks
You need to lock the blades from turning and undo the bottom clutch drive in such a way as you do not damage it. I use an old motor clutch drive to undo them myself. It has a left hand thread and a block of wood to hold the blade. Then you can remove the blade with shaft from the brass bush to clean and lubricate it. If the brass bush has moved up in the plastic housing you need to press/bang it down again. Then reassemble. If you wreck the clutch drive on the blade you will need to buy a new blade assy if it is separate to the beaker, if not you will need a beaker and blade unit complete.
Jun 23, 2014 | KitchenAid KSB560 5 Speed Blender
How to lubricate blade assembly.
Sounds like gears are slipping and blades stop turning. no obvious damage to drive socket or gear on end of blade shaft.cant remove drive socket any suggestions on removal? Blade assy fits very loosly into...
First thing is to find the small hole on the plastic piece below the drive socket and remove the silicone in from it. Next turn the drive socket until the little arrow on the drive socket lines up with the hole, then look thru the hole to see the allen wrench screw in there loosen screw to remove drive socket.
Sep 15, 2011 | Vitamix 5000 Work Top Blender
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Can't get drive coupling off bosch unversal blender blade fixture
what you need to do is hold the blades with a towel to protect your hand, then, use a visegrips needle nose to grab the coupling (pushing the guard down) and twist it loose. It may be very tight, when I loosened mine, the plastic portion of the coupling pulled off leaving the metal "nut" tight to the shaft. Either way, remove the coupling/nut in the standard "lefty loosey" direction. Many thanks to the people at pleasanthillgrain.com for walking me through the process. Blessings to you.
Mar 23, 2009 | Cuisinart SPB-7 SmartPower Work Top...
Bamix Mono Hand Blender - Black Single-Speed Handheld Blender Logo
715 people viewed this question
Top Bamix Blenders Experts
Ruth summersides
Stan Ford
Mai Lor
Are you a Bamix Blender Expert? Answer questions, earn points and help others
