Question about Apple MacBook Pro Notebook
I left my mack book pro under the seat of my couch iT WAS SAT ON, AND now it turns on the fan is working the cd-rom drive is woriking(disk inside will not eject). but the screen stays black, and the keyboard is non responsive. (caps lock light and numlock leds do not function when buttons are pressed. I also am not getting any sort of sound from startup or by pressing volume keys. Please help
    Brigadier General:
  • 3,513 Answers
The symptoms that you are mentioning are somewhat similar to those of a loose RAM or faulty RAM module. Please try to place the RAM on to a different module and check for display. If not then try a different RAM.
Loose RAM can also cause this.
Thanks
Posted on Nov 15, 2009
Mac book pro disc drive will not allow insertion of CD
Shut down the laptop. Hold the left mouse Boyton while rebooting. That should cycle the CD-ROM drive.
Feb 23, 2013 | Apple MacBook Mac Notebook
Hello.. I need some help. I am using toshiba satellite a1O system unit..my laptop was fyn till nw..all of a sudden windows doesnt load..when i turn the power on, the toshiba logo is shown..then black...
Hello
First thing you do is to see what hard disc installed in your laptop. You can check that by checking it in your bios system. To check in your bios system first turn off your computer then press delete while your laptop is booting up. Then you will see if there is a hard disk detected in your lap top if there is a detected hard drive this means you have a problem in your windows installed in your lap top.
There is also a reason why those message appear if the first boot of your laptop is the CD/DVD ROM. Check you CD/DVD ROM if there a CD inside this may the first on to read while the laptop booting up. Remove the cd inside your CD/DVD ROM. Then restart your laptop. Check your hard disk connector it may have some loose contact thats why your laptop did not recognize the hard disc.
Hope this can help keep on touch with fixya. Hope to hear some testimonial from you. . .
Aug 12, 2011 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
I tried to move my hard disk and cd/rom drive to a dell tower but did not work and now when i put them back in my compaq evo i am only getting 3 beeping sounds when i boot up then it turns its self off ...
Hearing more than ONE beep is "bad" news.
Check that the wires from the fan on top of the CPU are connected to the power-supply pins on the motherboard, so that the fan spins when power is supplied.
Check that the RAM is correctly seated in its slots.
Check that the video-card is correctly seated in its slot.
Disconnect the power-connectors from the disk-drive and from the CD-ROM drive, and then start your computer. If it still beeps, without these devices attached, then these devices are *NOT* the source of the problem.
If all else fails, take the computer to a qualified technician.
Jun 12, 2010 | Compaq Evo D500 PC Desktop
My computer has suddenly stopped detecting the Samsung CD-RW/DVD-ROM Combo Drive. It does not display E: drive in the Windows explorer. I am not able to play any kind of discs.
Right–click My Computer, click Manage, and then click Device Manager. make sure there are no yellow or red boxes in the left. if it is rede or yellow, right click and update drivers. If this doesn't work, turn your computer off then unplug. Open the case and re-seat the cables. Plug system in, and turn on. If you can't see the drive still under my computer you will need a new drive.
Feb 03, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Cd rom does not recognize any disk i have atapi 56max
the lens inside the cd rom wil hav to be cleaned
then it wil detect
if the problem still remains then u have to replace the lens inside the cd rom
Mar 07, 2009 | CyberDrive 56X CDROM IDE ATAPI (CYBER56X)...
No audio on toshiba sat pro
MAY BE THE ONE YOU TRANSFER THE HARDWARES TO DOES NOT HAVE SOUND DRIVER YOU NEED TO LOAD SOUND CARD DRIVER ON IT BEFOR YOU CAN HEAR SOUND.check the below site and see if it can solve the problem
http://www.driverfiles.net/Notebooks/Toshiba/Satellite-Pro-6100/download/page,sh,31303,221,19,.html
Dec 24, 2008 | Teac DW 28E CD-RW/DVD-ROM Burner
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
CD/DVD rom. CD part - does not work
Inside your DVD rom is two heads I believe they are diamond both do the same things which is to read them. The CD head is poked (Broken). Try cleaning it with the proper solution. If its no go then the latter I am afraid stands!.
Sep 24, 2007 | Dell Latitude C400 Notebook
Sunfire V-120 server / cd-rom not operating
It sounds like it may be a seating issue, try to reseat it. if that don't work try another cd-rom.
Dec 07, 2006 | Sun Fire V120 Server
Apple MacBook Pro Notebook Logo
27 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
