Question about Blenders
My GE dryer was making some squeaking sound and now the heat does not work and clothes are not getting dry
    Brigadier General:
  • 4,088 Answers
Check the dryer dual-breakers in the house electrical panel--push off, then on. If no help, check for ~230 volts AC at the two slanted slots in the dryer power socket. If ok, the problem is likely the heating element(s) in back of the drum are burned out or the internal thermostat is open. To remove the drum, remove the top (push a thin putty knife rearward at each front corner to release latches) and then the front panel. The belt must be released (from inside the lower back) and the rear center screws of the drum removed. When the drum is removed, it gives access to the elements and temp control switches. Be sure to vacuum out all air passages and wash the lint filter in hot water and detergent to remove fabric softener deposits. Don't forget the air exit hose to the outside. Replace the belt on reassembly if heat damaged or badly worn. Hope this helps!
Posted on Nov 15, 2009
Clicking sound plus smell of motor and overheating on 2 with dough hook for bread. i am making 2 large loaves at a time.
Sounds to me like you are overworking the machine. Get some advise from Kitchen Aid themselves, find a helpline and phone it.
Sep 16, 2015 | KitchenAid Professional 600 6 Qt. Stand...
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
Want to make dried date shake in vitamix. recipe is 20 pitted dates, 1 cup milk do I need to soak dates first?
Dry or hydrated, I have done both ways. I really didn't notice a difference? The vitamix just beats it up so good, I don't think it matters? But that is my opinion.
Aren't they good though? : )
Feb 16, 2014 | Vitamix TurboBlend 4500 Work Top Blender
Blades won't spin
The motor may have failed.
Dec 25, 2013 | Cuisinart Blend & Cook Soup Maker
The jar of the ge single serve blender got struck. How to fix it
Most likely the problem is caused because the base is not screwed all the way on to the jar. This could be from just not turning it on all the way or it could loosen while running. Make sure the base is tightly closed before putting is into the power unit. To remove it you can lubricate the tabs with some vegetable oil and then force it. GE service suggested that. I have heard of two people joining forces to get it off without apparently damaging it but no guaranty's. If you have the reciept it should have a two year warranty, at least mine does.
Dec 01, 2010 | GE Blenders
Was blending this morning and all the sudden the blade stopped spinning. all of the lights work, and I've tried putting it on "pulse" mode, but nothing can get it spinning again. any ideas?
Pretty much that is what happened to me. I found that the motor has 2 "thermal cut-offs" (SEFUSE 113oC). If the motor heats up even a little, these babies kill your blender. They are thermal fuses. Once they blow, it is over until they are replaced. To fix this, the motor must be removed. The spline gismo on top of the blender unscrews with reversed threads. I suggest unsoldering the lead wires from the power supply board, and replacing when done. The cut-offs are inside the taped on white cloth insulation on the top of the field magnets near the brush assemblies on both sides. I replaced them (both were blown) with 2 of NTE8242 ($1.60 each, 240oC 15A). These are way too hot, but that is what I had on hand. I thought that the electronics were defective at first, and I replaced the entire board assembly with a small/cheap ceiling fan wall switch /speed controller from the hardware store (600W 5A) for $10. The root cause of all of this is that the motor fan is not working. The airflow is blocked by base. I put small extenders on the feet and now there is much more airflow. Only time will tell if this is an effective fix. etc. It really makes me wonder how it got past UL approval.
Jul 26, 2010 | Cuisinart BFP-10 7-Speed Blender
My dryer is making a terrible squeeking noise
This could be your drum rollers on this unit. When they start to go out, they sound terrible.
This is an easy repair and you can save a lot of $$$$$$ by repairing this your self.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your brand and model number and we will get the correct part out to you right away!
We answer our customers calls from 7 AM until
9 PM CST so call us when you need us!
Happy Holidays to you and your family! Ella
Nov 11, 2009 | Blenders
I have a Bamix Immersion Blender, but it stopped working. Press it on and it makes a humming sound but does not move. Where (in Canada) can it be repaired or replaced?
Sounds like the motor shaft has broken from the impeller. If I had it I would crack the case and see if that were true.(You might see screws holding the case together- If not, they might be hidden under the cosmetic label. If it is true, you need factory help. You better call Customer Service for Bamix.
THis is from http://www.bamix-usa.com/:
The drive shaft is frozen i.e. no longer rotates although the motor still hums: place the operative part of the appliance for 5 to 10 minutes in a jug of hot water, then switch it on. In general the appliance will then work again - if not just try to free the shaft very carefully with pliers
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers Processor/Dry Grinder: Discoloration of the bowl (i.e. carrots) can be cleaned with a cloth impregnated with salad oil.
Oct 23, 2009 | Bamix Immersion Handheld Blender
Braun 4169 disassembly procedure
4169 blender dismantling. this device is not suitable to be dismantled but this is how I did it. 1 disconnect from the mains. 2 lever off operating lever button at opposite end to hinge 3 insert sharp screwdriver into gap by top lid at same side as cable entry and prise off 4 heat up the casing with an electric paint stripper, wear gardening gloves. 5 when the casing starts to get pliable, insert a driver into the gap above the operating button locating lip and prise away as far as you can 6 do this with the locating peg on the other side 7 work between the two until the whole thing comes apart 8 lever out the motor, it will slide out once loosened 9 wash out the blender drive shaft with boiling water and detergent 10 dry out the body and soak the inside with silicone oil 11 work the blender blade until it spins freely 12 clean everything up and push it all back together 13 if any parts are deformed with the heat gun reheat them to a pliable state and reform them as best you can 14 if it is all loose when its back together, glue the joints with superglue and spray with glue accelerator 15 test it and if it's no good chuck it in the bin and buy a new one 16 but mine works fine.
Oct 09, 2009 | Robot Coupe MP450 Handheld Blender
Spillage onto base of blender!
Usually leakage into the base can compromise the motor's performace. Since it sounds like this also has digital displays, you don't want to risk messing it up even more by turning it on. The company should have service places you can take it into to get checked out, some might even do an estimate for free. I would call the company and see if that's possible and maybe just a quick cleaning can fix it.
Mar 05, 2009 | Krups KB7207 4 Speed Blender
Open Questions:
Blenders Logo
98 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
