Question about Sony Ericsson Walkman® W880i Cellular Phone
I PUT IN A PASSWORD TO STOP PEOPLE USING OTHER SIMS AND I FORGOT THE CODE WHEN I TOOK MY SIM OUT. WHAT SHOULD I DO?
How to resart in starting if put new sim in my mobile it asking security code how im restart my mobile
If it is a used phone and it was never wiped. Then the old security code is active. Changing the sim does not change the security code of the device. If it is asking for a sim security code, then the sim card is locked and you must have the code or the sim is just a piece of plastic. Did the service provider put a code on the sim and forgot to tell you.?..Take the sim back and ask for another without the security code on it. Sims can be coded so that if they are stolen they cannot be used in another device.
Jan 24, 2015 | Cell Phones
My samsung gt-s5230 keeps saying sim password i have forgot what sim password is how do i get sim password off
Contact your ASP (administrator service provider) like VODAFONE as you will not be able to use this sim card at any other phone except your password Or you can put your password more than 10 times then sim card will be purged finally you can make sim swap and it will work normally
Dec 02, 2012 | Cell Phones
Sim password blocked
PUK Code
PUK stands for Personal Unblocking Key. This is a unique eight-digit code specific to your SIM card. This is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack. If you do not have this then - Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give them your account details and they have confirmed your identity. For details to obtain the PUK code for the SIM card, please click on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Aug 12, 2012 | Cell Phones
How to unlock phone lock of Samsung C3010 as i forgot the password
You can use your puk code to unlock samsung c3010 old password and you can get puk code from your sim card bundle or you can asking from your network provider. The idea is put any password until your phone asking your puk code, then enter that puk code. This method should be unlock samsung phone from old password. Good luck!
Sep 06, 2011 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
I forgot my password to unlock my blackberry bold 9700 on att, all my info is stored on it and i cant get to it. please help...
Maybe you can try to unlock your blackberry phone using blackberry bold 9700 unlock code for att network. It will make your blackberry unlocked and you can use any sim card on your phone so you can try to look at your data using another sim card.
Jul 14, 2011 | RIM BlackBerry Bold 9700 Smartphone
When i put another Sim in this phone, phone need password. but i forgot password. please help me .
wats the method to activate barring password ,wats the default password code plz help me out.
Jan 24, 2011 | Nokia XpressRadio 5030 Cell Phone
How to break samsung d880 sim lock password.
The best bet is to put your original sim (d880) , but don`t lock it.
Ring the supplier for this sim explain the situation and they will unlock it for you.
Your second sim will then work in your phone , no problem!
Dec 14, 2009 | Samsung D880 Cellular Phone
I Forgot My Password!!
The above code works. When it says insert sim card, simply start typing in the code. When complete it will tell you it is resetting and will restart by itself.
Jan 27, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Samsung e-250 i need unlock code
Please follow the instructions carefully! Following are the 12-point instructions to unlock your Samsung E250 phone:
1. First do a CUSTOM RESET by tying in:
*2767*2878#
(Phone may display foreign language – don't worry! The last digits after the * will appear as - - - -; this is normal)
2. Turn off your phone
3. Take the battery and SIM out of the phone
4. Take a wrong network SIM (a SIM the phone does not currently accept) and insert it ONLY HALF way in, so when you turn on the phone it won't detect the SIM. Very important so the phone won't ask for network password and will show "Insert SIM" message.
The process of inserting only half of the SIM. I advice you to take care and do it with a soft approach as you might not have done this before.
5. 2. Now put the battery in carfully behind the protruding SIM card and switch the phone on. The phone must show "Insert SIM" message.
6. 3. Without turning off the phone, now push the SIM card all the way in, at this stage the phone must continue to display the "Insert SIM" message with the WRONG SIM inside.
7. Now make a FULL RESET by typing: *2767*3855#
9. Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
8. The phone should reboot working with "wrong" SIM inside. (Do not turn off the phone)
10. Disable network lock by typing: #7465625*638*00000000#
12. Check this is done with *#7465625#
If your phone is not unlocked please retry the above ensuring all steps are followed to the letter, 9 out of 10 people who have problems have made a simple error and find that when they repeat all the steps it works.
Jan 08, 2008 | Nokia 1600 Cellular Phone
Sony Ericsson Walkman® W880i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
