Question about Tools & Hardware - Others
How do I change the sandpaper in my Black & Decker Sander 7448? I lifted the two levers and the sandpaper came out but now I cannot get them to close tightly around the replacement sandpaper.
    President:
  • 2,702 Answers
There are many types of sizes for this sander check you have the right size first,,, after that check that the return springs in the belt tenshioner are poping out fully
Posted on Nov 15, 2009
Black & decker 7448 sander sounds & smells like motor ceased up. only makes a humming noise & feels hot.
could have had a bearing problem that caused the motor to cease up, It might be time for a new one unless you are handy, if so I suggest going to dewaltservicenet.com and downloading a breakdown for the tool and make note of how you disassemble it to find the problem, If it is the armature or field it might cost less to replace it.
Oct 23, 2011 | Black & Decker 7448 1/3 Sheet Orbital...
Could you please tell me what sandpaper goes on the Mouse sander/polisher model # MS500
ok this easy go to the hardware store and ask for the sandpaper to fit your sander, black & decker make sandpaper specifically for that sander. now depending what job you want to do will determin what grade you want sand paper works like this the higher the number on the paper the finer it is so for example 80 is very coarse you would use that for eg stripping thick paint on a door but 2000 is very fine and is used for eg sanding varnish between coats. ok hope that helps let me know how you go.
Mar 11, 2011 | Black & Decker Mouse Sander/Polisher
I am recently widowed and don't know how to get the sand paper out of and onto the sander
At both ends of the bottom pad, there are metal fittings that have a rectangular hole in the middle of them. Take a regular head screwdriver and put the tip in the hole and carefully but firmly lift up and hold while at the same time pushing the narrow edge of the 1/3 sheet sandpaper up under the metal piece which kind of looks like a C on its edge. Then let down the metal piece with the screwdriver and that edge of the sand paper should be held in place. Do the same thing for the other end of the sandpaper, making sure to pull the sandpaper sheet tight against the rubber pad.
Oct 08, 2010 | Black & Decker 7448 1/3 Sheet Orbital...
Black & Decker Cyclone won't power on
If the sander was on for a long period of time maybe 20 mins or so then the switch has probably stuck in the off position when you turned off. Try a new switch or test the old one. Try Solent Tools on 023 80578057 for spares or further advice.
Dec 10, 2009 | Black & Decker Black And Decker Cyclone 4...
Replacing the sand paper
Ok on the front and rear of the sander you will see metal wire holders. These extend each side of the sander and form a loop to which you can release them from their holder. Release each side ring and then that will lift the wire holders up at the front and back of the sander. This releases the sandpaper sheet. Now cut or add a new sheet that is long enough to fit over the sander base and fold up under the wire holders. Then clip the rings from the wire holder back in place while holding the sandpaper under the wire holder to hold the sandpaper in... same process for each holder (one front and back). That's it!
Jun 13, 2009 | Black & Decker QS800 2.0 Amp 1/4 Sheet...
Tools & Hardware - Others Logo
571 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
