Question about Asko 24 in. D3250 Built-in Dishwasher
D 3250 asko dishwashers - 2, both not working.
I have two D 3250 built in Asko dishwashers - 2, both not working. I had a party, started one and then an hour later started the other. When I went to empty them this morning the dishes were not clean. Both have a small amount of water collected in the bottom of them. I cleaned out the catch cup and soaked up the water. I tried to run them again. The lights are on, it makes a short draining noise at the beginning and then stops (both of them!) I have turned them both on and then off, switched the cleaning cycle, etc.
  • pbucci6 Nov 17, 2009
    I unhooked both hoses, vacuumed them out and could feel the suction when vacuuming inside the washers. So I don't think the hoses are clogged. If two dishwashers are hooked up to the same sink, is there one drain pump for both? It just seems strange that both went out on me in the same night.
  • 555 Answers
Per your notes, There is no way that both DW gets the same drain pump. I believe it uses a Y connector at the hose. I'm sure this is an installation issue. If one DW is having problems with the drain, the other one will be affected.
If both were connected at the same drain hose, the pump from one push water to the other one. I highly recommend you to get a service tech to determine and correct the installation issue. This is a quite dirty job, I don't think you may want to do it.
Posted on Nov 17, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Check the water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible.
This would have happened as the dishwasher was overloaded with more than prescribed number of dishes. Check the spray arm and pump cover for splits or leaks. As the dishwasher is not draining properly, this issue is related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 16, 2009
Fault indicator on Asko D-3250 (heavy wash/ too much water has en
the float switch must be stuck the up position or water inside the pan or a bad float switch..
hope it helps.... if NOT let me know more about your problem...
Sep 25, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Can't get my Asko D3232 to start
Try flipping the breaker off and on. If that does work it maybe the control panel.
Sep 25, 2017 | Asko TouchProof D3232XL Stainless Steel...
Power on Press Start.Lights flash. Close door . Fails to Start
Possible causes
1. Main switch is OFF.
2. Door not properly closed.
3. Fuse has blown.
4. Power supply plug not plugged in.
5. Water tap not opened.
Please check these and let me know if any have worked.
And please remember to rate me.
Feb 02, 2009 | Asko D1996SS Built-in Dishwasher
Asko d1716 door switch
Below is a link to get a PDF of your washer. Cannot say if the solution is easy to resolve, but with the manual you have numbers and sources to get more assistance. Hope this helps,
Sea Breeze
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Jan 31, 2009 | Asko D1716 Built-in Dishwasher
Asko D3250 not working
If the first start button is blinking then there is a door error...the door switch is not closing... to repair
1) turn off the power at the breaker...
2 ) remove screws in the door T20
3) remove contol panel (slide up)
4) place wire tie behind micro switch on door latch...
5) replace door latch and door.
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 25, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko D1716 dishwasher problem
I also have an Asko D1716 dishwasher. The water stopped flowing. I replaced the water inlet valve and I have another problem, but the replacement of the fill valve is now letting in water. You can call Asko at 1-800-898-1879 to order the parts. If you order from Asko, I'm told you have some warranty on the parts. Anyway, the screws take a star drive and there is a front plate and back plate you will need to remove. There are approx. 4 screws on the front and 4 screws on the back. Just remember to unplug it before starting any work. The fill valve is in front of the machine. There are 2 screws holding it in place from the front. You will need to remove it out the back though to replace it since the fill tube to the tub is short and it wont allow you to pull it out the front. The repair is really easy once you get started.
Hope this helps,
Sargeantfod
Jun 11, 2008 | Asko D1716 Built-in Dishwasher
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Asko 24 in. D3250 Built-in Dishwasher Logo
63 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
