Question about HP Computers & Internet
Hp pavilion a450n turns on but wont open past countdown
    President:
  • 414 Answers
Probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
2) 4) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
3)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
4) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
5) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
6) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
check the battery [both main power & cmos], in case of laptops..
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(uncheck on the) Automatically Restart;
b)'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 16, 2009
HP pavilion a6700y there is no VGA no input signal
Make sure that the connections are tight. and plugged into wall.
If this wont turn it on monitor may be bad. try different cable and/or monitor.
Jun 07, 2014 | HP Pavilion a450n PC Desktop
Repair HP pavilion a6700y VGA no input signal
change the video card or check the cable.
A450N needs new monitor - what monitor specs are required?
Any monitor will do unless you are trying to get one with the built in speakers that you have. Just make sure the monitor has the same type of connection that you currently have (VGA, DVI, HDMI, etc).
Apr 23, 2012 | HP Pavilion a450n PC Desktop
Headphones doesn't have audio when pluged into headphone jack but will work when pluged into speaker jack. has worked in past when pluged into right jacks
Right click on the volume control that appears on the tool tray and the foot of the page - in there you will find all the audio adjuctements and will make it easier for you to self diagnose the issue.
Mar 18, 2011 | HP Pavilion a450n PC Desktop
My hp a450n wont turn on after we had a power outage. It was in a surge strip as was the router etc. Everything else was fine. There is a green light flashing under the power cord into the computer?
Power supply was probably nuked. You can get a replacement from ebay or usually a local computer repair shop. They go for around 20-35 for most "generic" power supplies. Unless you're a hardcore game or crazy you probably will just need an ATX power supply. Easiest thing to do is just take it down to a mom and pop computer place and have them sell you the right one.
ANYONE can replace it. It's just four screws to take it out, then just plug the cables back.
Some HP models use a proprietary power supply, if this is the case with your model then eBay is the place to get a replacement. Just match up the power supply model numbers and you're good to go.
Let me know if you have any other questions.
Nov 22, 2009 | HP Pavilion a450n PC Desktop
My hp a450n won't turn on. We had a thunder storm
Was the PC running when the storm struck? In that case changing the power supply knows as SMPS which is inside the cabinet needs to be replaced provided your monitor when independently connected to a power outlet, gives a display or says 'no video signal'...................sodeep
May 15, 2009 | HP Pavilion a450n PC Desktop
My hp a500n will not turn on
Check your BIOS battery make sure it is working correctly and that it is not out. You can use a battery tester to see.
Feb 14, 2009 | HP Pavilion a450n PC Desktop
HP a450n P4
Re-install the network adapter drives correctly with the CD you get
if the network card still not working
remove it carefully from the slot and clean the lan card and the PCI clot.
replace the lancard and re-install the drives
Restart the system after installing
Let me know if your problem is solved and rate me as FIXYA!
Apr 07, 2008 | HP Pavilion a450n PC Desktop
Computers & Internet Logo
116 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
