Question about Panasonic Lumix DMC-FX500 Digital Camera
I have some dust on the sensor of my fx500. not sure how it got there, but it's there. anyone tried taking one of these apart for cleaning? is it fairly straight forward?
I have the same camera and the same problem as I always keep the camera with me in my pocket. The camera can be taken apart and cleaned if you have a clean work space. I would not attempt this if you do not have experience separating electronics with delicate ribbon cables. Wants the camera is apart it is easy to see why this happens as there are several gaps in the lens barrel. If you have patience it can be done but I recommend as much of a dust free environment as possible, some cleaner for a DLSR sensor and some air duster. When I tear my camera down I start with the bottom and work my way to the sides. The most difficult part about separating the camera for me is the top portion of the camera where the zoom control an on off switch is located is attached permanently to the flash and the flash capacitor. This needs to be wiggled with the utmost care and pulled straight up and out of the camera. Once the camera body, sides front and top are separated the LCD screen lifts up and there are a couple of screws that screwed directly into the back of the sensor mounting bracket area once these screws are removed the sensor is easily accessible. Again you do not have experience with not touching anything while you're doing work like this do not attempt this. Once the sensor is pulled up a can be dusted and cleaned my typically blowout the lens barrel with the air duster, obviously making sure that you do not tilt the can because even the slightest residue will set you back even further.
Posted on Jul 10, 2010
  • 2 more comments
  • portillomj Aug 17, 2011
    "...there are a couple of screws that screwed directly into the back of the sensor mounting bracket area once these screws are removed the sensor is easily accessible."
    Bad news, in some newer models they (Panasonic engineers) replaced the couple of screws for unscrewed rivets, so no access to the sensor is possible. That way you have to go to the "customer service" (is a way of speaking) where they make you cough at least 60 €, although sometimes, if they consider that you are gullible enough they come out with the well known line of "there is sand inside that scratched the lenses". Sand is not covered in the guarantee. That amounts to a total ol 170-200 €. So, we have a problem with this rogue brand. They screwed the Lumix design (dust, dust, dust), so they blocked the "surprisingly easy solution" in Youtube (with the rivets), keeping busy the guys at their customer services around the world. I suggest a total boycott of the brand.
    Miguel
  • Daryl Ng Jan 23, 2013
    What screwdriver did you use?
  • Marc Jan 23, 2013
    Philips .000, its pretty small but most jewelers kits have one.
    Brigadier General:
  • 11,967 Answers
What makes you think you have dust on the sensor? And no, you can't take apart the camera to clean it.
Posted on Nov 15, 2009
Hp mg-0982 moust take apart
Hi!
If that's the case, just use fine brush in cleaning. Un-plug it and plug again. Restart your computer.
Jan 19, 2014 | HP Computers & Internet
How can I take apart and clean inside lens? There is a specj of dust that is showing up in my pictures.
Sensor cleaning on your model is a job for professional technicians only and therefore not cheap. Dismantling your camera to get at the sensor requires specialist skills and knowledge and due to the small sensor size it must ideally be done in a sealed room with high levels of dust extraction if you want to avoid making the problem worse.
Any attempt at unauthorised disassembly will also invalidate any warranty you may still enjoy; even if the original warranty has expired there are sometimes camera faults which later arise that manufacturers have been known to retrospectively extend the warranty for so you potentially lose those rights as well.
A safer alternative is to use a supersonic vibration cleaner on the camera. These are sold to the public and to jewellers/opticians as a means of cleaning without chemicals and are usually filled with water, but you can find one with a large enough bed to sit your camera in and then it can be used dry. Your camera must be switched off when you try this, and must sit on it's base. The latter allows the dust to fall downwards and get trapped on the internal sticky dust trap built into your camera. If the camera is oriented any other way then you may dislodge trapped dust which may then fall onto the sensor. If you cannot find a suitable supersonic cleaning bath then you may even find that a ******** (yes, I DO mean the adult toy) set on it's fastest setting will achieve the same result. You need one that vibrates, not one that resembles an industrial jack-hammer...
Failing all that your only remaining option is to just accept that you're going to have to process out the artefact on every shot until it eventually falls off the sensor of it's own accord (no guarantee that it will though).
Good luck, and please take a moment to rate my reply.
Sep 13, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
I have a Panasonic Lumix DMC - FX500 and when I take pictures they look as if there is a fingerprint over the picture. I have cleaned the lens so it definately is not a fingerprint. any ideas what it...
I have had the same camera for quite some time and have seen similar issues. I do not take care of the camera all that well and it spends much of the day in my pocket as I find myself quite frequently needing a shot of something. Based on my research and own experience dust on the lens is quite common. If you're fond of the camera but unable to take the camera part yourself local camera shop may be able to clean it for nominal fee. I would not pay more than a bench fee of $20-$40. If you're adventurous the camera can be taken apart with a few simple steps as long as you're careful and familiar with how to remove ribbon cables in tight areas and have a clean workspace.
Jul 05, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
How do I clean the dust off the sensor on my Canon Powershot SD1100IS Is there a tutorial that shows the step by step process to take the camera apart and get to the sensor?
Sensor cleaning is done on DSLR cameras, not on point-and-shoot cameras. If you take it apart without the proper equipment, alignment tools, and not to mention knowledge, you will end up with a paper weight.
Apr 18, 2010 | Canon PowerShot SD1100 IS Digital Camera
I need to clean both cooling fans on a sony vaio vgn cs215j/p laptop
if you just need to clean the dust from them, most stores that sell computers such as wal mart radio shack , best buy etc. sell cans of compressed air to blow out all the dust. just make sure your computer is turned off before you blow the dust out. i hope this helps!!!
Jan 14, 2010 | Sony VAIO VGN-CS215J/W Notebook
Dust spots on images
this will give you the idea how to clean the lens and have lens cover which is available in market to protect it from dust
http://www.picturecorrect.com/photographytips/207/cleaning_camera_lens.htm
thank you
Sep 22, 2009 | Leica M8 Digital Camera
FX500 Parallel lines semi transparent / ribbed effect
hi there i have the same problem did ytou get it repaired, what was wrong?
Sep 13, 2009 | Panasonic Lumix DMC-FX500 Digital Camera
How do i take my emachines m6811 laptop apart for a cleaning?
Well the company that made emachines at that time (Trigem) went bust so no support from the makers....
Best thing to do is search google for a dismantle guide or dissasembly or somthing like that...
Sorry not the most helpful answer in the world...
Matt
Jan 07, 2009 | E-Machines M6811 Notebook
Dust inside my HP All-in One show up on scanned pictures
Get a can of compresed air, open up you machine and blow it out. Also don't froget to clean your scanner glass.
Oct 29, 2008 | HP PSC 1610v All-in-One Printer
Spec in Shots
It is likely debris (dust) on the CCD sensor. You can buy a cleaning swab kit on sites like eBay
Jan 20, 2008 | Pentax *ist DL Digital Camera
Panasonic Lumix DMC-FX500 Digital Camera Logo
369 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
