Question about Vizio 42 in. LCD TV
Vizio 42" powers up and vizio turns white, back light on but no on screen displays and no sound or picture from any input. only way to turn off is to unplug power. Tech support narrows it to the main board OR logic board. Any guesses as to which one??? Also has anyone ever had 110VAC on heat sink of power board???
  • mjflips_2 Nov 16, 2009
    No problems with power board. Model #VU42LFHDTV10A testing shows logic board is for HD functions and main board handles processing, inputs and on screen displays, but nothing showing signs of anything bad visually. Main Board 3642-0122-0150(4A) is the OEM replacement 3642-0122-395R?? Also just a question, service port for this is a RJ45, is it possible to terminal into this and run service diag. with PC as dumb terminal??
    just to clarify logic board not main board???
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This is happening due to the power board or the X-sus board. However, this usually happens due to the Power board. You'll need to disassemble the TV to be sure where exactly the issue is. If its the power board, then you'll be able to see swollen/bulged capacitors on the board.
However, if its a X-sus (logic board) then you'll need to check the connector cables connected to it and also the components connected on the board. You'll need a multimeter to check these things out.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 15, 2009
  • Rylee Smith
    Rylee Smith Nov 16, 2009
    Hi
    If its not the power board then definetly the issue is with the X-sus board (logic/video display board). And you can't judge a bad board or component by just looking at it. You'll need a multimeter to check all the boards and components.
    You'll need service diagnostic kit to attach it with the RJ45 connector and also the know-how of the kit.
    Thanks
    Rylee
  • Rylee Smith
    Yes, I mean X-SUS Board/Video Board.
    Thanks
    Rylee
When in antenna mode why does it freeze then turn off and come back on in HDMI1 mode?
[PDF]USER MANUAL - Vizio
www.vizio.com/documents/downloads/hdtv/.../UM_E550iB2.pdf
VizioAny other voltage than the specified voltage may .... Do not locate the antenna near overhead light or power circuits, ..... the instructions that came with your mount. ...WIDE. Switch the display mode. MUTE. Turn the audio off or on. BACK ..... Zoom. Normal. Note: Aspect ratio settings may vary by Input source. HDMI-1. HDMI- ...
[PDF]USER MANUAL - VIZIO
cdn.vizio.com/documents/e40c2/um-e40c2.pdf
setting and this is the setting in which power savings will be .... electric shock, do not perform any servicing other than ... connected to the TV, make sure that the antenna or cable system .... Locking and Unlocking the Custom Picture Modes ..... ...... .....BACK. Go to the previous on-screen menu. MUTE. Turn the audio off or on.Missing: freezes
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Jan 21, 2016 | Vizio E420VA 42 in. LCD HDTV
My Vizio has power, has sound, just no picture. The vizio light does turn blue.
Not sure what model you are talking about, but in general it would be helpful to check the setup menu on the TV. The menu will typically display regardless of the display settings. A factory reset of all the controls may help. (This is in the manual for your model #.) Also check the input cables as well as then input settings in the menu for each input you want to see on the screen.
Jan 15, 2015 | Vizio Televison & Video
When turned on, screen goes black, but power light stays green
It sounds that the main digital board to this TV is faulty. Contact any service technician.
Jun 26, 2013 | Sanyo LCD-42CA9S VIZON MULTISYSTEM 42" LCD...
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Oct 17, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
My vizio vx32L turns on but only a black screen shows up
Sep 30, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
My 42" Vizio LCD Tv Turns on/ wont turn off or display picture.
If you haven't tried it yet, pull the AC plug and let it sit overnight. Your set and most later ones do have microprocessors in them that can have 'lockup' problems similar to a resonal computer crashing.
If it still isn't responding to set-mounted or remote controls, you may have hada power supply failure.
Aug 06, 2009 | Vizio Televison & Video
Vizio vx42l hdtv back light
If backlight went out then sound should still work. Are there any indicator lights to show power is coming on anymore? Try unplugging for 30 seconds, hit power button a few times, then plug back in and try to turn on. This drains any capacitors of power to attempt to reset (basically clearing the TV's throat).
Can also try something on a different input. If current input is composite, S-video, or component, try using DVI or HDMI connection as this uses a different board in the TV. If that fixes it, then at least you can try to replace one board instead of entire tv. :)
Apr 06, 2009 | Vizio VX42L 42 in. LCD TV
Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Mar 11, 2009 | Vizio L32 32 in. LCD HDTV
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
168 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
