Question about Dryers
Zanussi TC470 Tumble Dryer - Drum not rotating
Hiya - my beloved Tumble Dryer of 10 years is not rotating. Still heats and still makes noise but drum is not going round. My gut feeling it is the belt but when I have phoned local repair man he has huffed and puffed and wants to charge me £35 to come and take a look. My dilemma is whether to have it repaired or buy a new model with warranty. If it is just the belt, I think it is something my husband could do and I could get further use out of it - any thoughts?
  • Tom milush Jan 09, 2008
    runs sometimes then it stops for a long time sometimes i'll rotate it by hand it'll start but only sometimes
  • healeybol Nov 28, 2008
    drum not going round still has heat still sounds normal
Both sound like the drive belt to me - I've just replaced mine.
BirdG is probably snapped.
mildew is on the way - the motor will burn through it if left unfixed.
you may be able to tighten it and get more time out of it but sounds like it has a worn patch and will go soon.
(tightening is easy- just remove the fan belt cover at the back,slacken the large bolt below the motor and rotate the motor to push the jockey wheel harder against the belt, then retighten the bolt.
replacing is harder.
Posted on Feb 09, 2008
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
May 22, 2015 | Beko DSV64W White Vented Tumble Dryer 6...
Beko DRVS 62 W Tumble Dryer Squeakig
I had a problem similar to this on my Frigidaire dryer. I found that there is a felt ring that goes around the drum inside. This acts like a washer to prevent the drum from rubbing on the housing. On mine, the felt somehow got pushed in some and the drum was squeeking as it rotated. I had to order a whole new drum and replace it since on my model it was part of the drum.
Feb 11, 2014 | Dryers
Zanussi tc470
DEFO BEARINGS WHEN YOU SEE THAT DUST A REAL SIGN
Jan 22, 2014 | Dryers
Tumble dryer is very noisy
i had the same problem.it ended up being the bearing that holds the drum in place.it had worn that bad that the drum was rubbing the bottom of the dryer.the bearing is located on the back of the dryer if the bearing is worn there will be like black dust around the area.this does stain so be carefull
Feb 19, 2010 | Miele Dryers
Fit felt drum seal to zanussi td4212 w tumble dryer
I take it that the belt is ok and the drum is turning.The heater comes with thermostats fitted as a complete part.There is an overload safety thermostat which is situated inside the drum and above the door,it is held in place with a self tapping screw then prise open the plastic cover and then the thermostat will pull out,if replacing remember to refit the small gasket.Have you checked the filters and exhaust hose for any blockages as this will affect the heating.
Hope this helps
Feb 12, 2010 | Dryers
Zanussi tumble dryer
take it apart and you will see that the belt is probably find the belt broke
Nov 05, 2007 | Kenmore 64902 Electric Dryer
Making an electrical noise, but drum not turning. Sounds like it's shorting.
I'd suggest - remove the top cover. Switch on. Push the drum around - see if the drum picks up speed and continues to run. If this happens, it means that the motor Starter capacitor has gone dud and will need replacing. Note- If the drum doesn't continue to rotate after you shove it, switch off immediately. It will likely then be a faulty motor.
Sep 13, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
778 people viewed this question
Top Dryers Experts
