Question about Fuji FinePix A820 Digital Camera
I have a fuji A820 and when the power button is pressed with fresh batteries it will turn on for a second then shut down. the camera will not stay turned on
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 15, 2009
I get no power when using fresh AA batteries or charged (Ni-MH batteries). Camera works fine when using AC power adapter.
Please make sure that you're using the LR6 AA sized batteries and also the terminals of the batteries are correctly inserted. Also make sure that the terminals of the battery compartment is clean without any obstacles or dirt. Also, try power reset and check if it helps.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
If the issue persists, try the factory resetting. SETUP MENU-->RESET ALL--> OK
This should resolve the issue.
Thanks for using FixYa.
Jun 06, 2011 | Fuji FinePix 3800 Digital Camera
My finepix s9000 will not turn on, it clicks a few times and then there is no power on screens or other features
remove the batteries, let it sit for a week or so, then load fresh batteries and it will turn on. Apparantly the auto shut down feature prevent it from turn on until the internal memory is erased. This is a stupid problem that Fuji should fix
Jul 09, 2010 | Fuji FinePix S9000 Zoom Digital Camera
Camera shuts down when button is pressed, even with fresh batteries
Go to flash option and off it if it works then flash circuit problem it might be short circuit there,otherwise it might be oxidize in switch it need to clean
Mar 18, 2010 | Fuji FinePix A820 Digital Camera
Fuji FinePix A820 Won't reset
To solve this problem you need to use the SP shooting mode.
Replace battery with new High power ones. and switch ON keeping pressed the PLAY Button.
If still does not retract disable the flash and repeat the operation without the XD/SD Memory Card inserted. It will then close the shutter magic.
Regards,
PDG
Jun 19, 2009 | Fuji FinePix A820 Digital Camera
Camera turns on for 2 seconds or wont turn on at all.
There is no hardware reset on this model. We have many situation on different make digital cameras that uses AA batteries that would not turn on with some other AA batteries due to Amp requirement on the batteries. Which means that some circuit design would work only with rechargable batteries because they have more power due to higher Amp power. So I would try rechargable batteries for the last resort. -James
Apr 12, 2009 | Fuji FinePix A820 Digital Camera
Fuji S3 Pro
I had this problem yesterday. I discharged and recharged several sets of batteries and the set I had the problem with continued to with the one shot problem the other sets workrd fine.
Jul 17, 2008 | Fuji FinePix S3 Pro Digital Camera
FinePix A350 Power Button stays down after being starting camera
This just plain shouldn't happen. Call Fuji while your warranty is in effect, and have them fix or replace it.
Mar 23, 2008 | Fuji FinePix A350 Digital Camera
FUJI FINE PIX E500. TURNS OFF WHEN I TRY TO TAKE A PICTURE
Make sure batteries are making good contact
with the battery terminals, and are clean
Nov 15, 2007 | Fuji FinePix E500 Digital Camera
Fujifilm A700
hi use a fuji s5600 which is ok for my need's but also the batteries are very fast down, i checket it to contakt for the battery is not good my tip clean out the battery shelf and try to tighten up the small srews inside, may open it and close again and you can use a power messure if the power goes true or not. sorry my english...
Sep 22, 2007 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fuji FinePix A820 Digital Camera Logo
302 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
