Question about GE Profile Spacemaker Over-the-Range Microwave
Ge profile microwave jvm1490wd003, burned out interior light... know it was somewhere behind the control panel along the right of the microwave, opened the panel, can't find the light bulb! it was way too bright to be an LED, so where is it?
  • 4 Answers
SOURCE: GE microwave interior light bulb replacement.
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
Posted on Dec 26, 2007
MicrowaveSvc
  • 9047 Answers
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
IFIXALL
  • 868 Answers
SOURCE: ge profile spacemaker XL 1800 undercabnet microwave
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Posted on Sep 10, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Sep 16, 2008
  • 181 Answers
SOURCE: microwave not working
faulty relay or solder joint on the power module, but a bad door switch is most common.
Posted on Nov 13, 2008
What is the Interior Cubic Foot capacity and the wattage of my GE Profile Microwave JE1540WW02?
GE oven model JE1540WW02 has a capacity of 1.5 cubic feet, and cooking power of 1000 watts. The power is listed on page 14 of the owner's manual here.
William E. Miller
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 15, 2017 | GE Microwave Ovens
How do you replace a GE Spacemaker Oven Profile JVM1490WD003 handle ?
usually you need to demount the front panel
then remove its face unit as it will have a back guard unit
so they split apart with screws usually counter sunk machine screws
then the front unit section will have the handle attached
de mount it and replace and back step
i find if i place all the screws like a map of where they came from
then when placing a screw in metal or plastic
turn the screw anti clockwise {to the left}
till it clicks down and drops a bit
you get a feel for it so practice
once you do this you can almost guarantee your on the correct threads when you wind it clockwise {to t he right} to secure
esp important with plastic
if you drop in the wrong thread you end up with a unit thats plastics holes
no longer hold the screws turn turn isnt good
when you can use this trick
Aug 14, 2014 | GE Profile Spacemaker Over-the-Range...
JVM231WV001
It sounds like instead of an overheated magnetron thermostat tripping the power, you now have a defective door switch.
Our door switch help file is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 27, 2012 | GE Profile Spacemaker Over-the-Range...
Ge profile microwave jvm1870sf02 buttons don't work do i need to change the control panel frame or Bkt c/panel
You will need to change the keypad along with the control board, because they are essentially of one piece. But the part will equal, if not more than a new microwave oven.
Apr 08, 2012 | GE Microwave Ovens
GE JVM1540sn1ss Microwave loses all power including interior light, control panel, etc. I have to set the clock each time. I can wiggle door or control panel and power comes back on. I appears there...
It may be a loose fuse holder or a rare condition, an intermittent fuse.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
If you need further help feel free to contact me with your full model number and symptoms.
Jul 06, 2011 | General Electric Microwave Oven
GE profile spacemaker mircoware oven change interior light bulb
Check behind the grill on the front top of unit. you can remove it by takign out a few screws from the top. There may be an access door there, if not unit would have to be pulled down and the case taken apart.
Dec 02, 2009 | Microwave Ovens
How to change the handle for ge profile spacemaker oven model jvm1490wd003
You will need to access the door handle mounting screws and remove them to replace the door handle. To access the screws on MOST microwave ovens, you must remove the inner door panel that goes around the perimeter of the glass. This can be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches. NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Oct 16, 2009 | GE Profile Spacemaker Over-the-Range...
How do I open the front panel of GE Spacemaker 2.0 ? Fuse?
there are screws either on top of or in the grille that allow you to remove it. after screws are removed, open the door, pull lightly toward you starting at the control side if it does not pull, then it may have to be pushed toward the hinge side, then pulled out. behind the grille, is the screw attaching the control panel. lift the panel up before pulling out. Just to add a thought,if the display lights up it is probably not the fuse, although, in some models there is a high voltage fuse, it is pretty rare.
Jun 16, 2009 | GE Profile Spacemaker Over-the-Range...
GE Profile Spacemaker Microwave Died
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode, transformer, or capacitor or a bad magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.htm
Dec 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE PRofile Spacemaker 2.0 - power off
I would suspect the magnetron thermostat or the oven thermostat. In some models, they are called TCOs or thermal cutouts.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 15, 2008 | GE Profile Spacemaker Over-the-Range...
GE Profile Spacemaker Over-the-Range Microwave Logo
168 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
