Question about Cell Phones
The battery does no charge and the battery is new
Why does system battery not charge ? new battery and new charging kit show no improvement on laptop. well charged battery works but not recharging.what is wrong ?
well this is a hardware problem.in this case your charging stage is not work.i am showing you a picture in the yellow marking fat 's are shorted if you can change these components the issue will be solved.sorry for bad english.
Jun 18, 2014 | Dell Inspiron Mini 10 N450
Batteries wont charge
If there is less than 10 volts on the new batteries, then use an automotive NON automatic battery charger to charge the batteries individually.
Feb 08, 2014 | Pride Health & Beauty
Cobra Micro Talk PR4750WX.New rechargable batteries will not charge in provided charging cradle.
The original Sanik batteries have a negative side with about ten mm of metal showing on the side. Trim the plastic off your new batteries to match and the cradle charges again.
Dec 11, 2012 | Cobra 22 CHANNEL 2-WAY RADIOS
Battery is not charging with new adapter
Clean battery terminals with a stiff toothbrush, plus the new battery. If no change! charge circuits need to be checked for output voltage, if okay! new battery is defective, If no! the charge circuits in the motherboard are the issue "very rare"
Mar 18, 2012 | Gateway Computers & Internet
I have new laptop how many hour battery charge first time
First Time Charging
  • The amount of time it takes for your battery to fully charge depends on many factors, like your battery type and operating system. Many newer laptops will charge in 15 to 20 minutes, while others can take a few hours.
    When you're charging your battery for the first time, charge it fully before using your laptop. You may have to go through a battery cycle a couple times before your battery begins performing at its maximum capability. To do this, charge your battery fully, let it discharge to about five percent, and then fully charge it again
  • Read more: For How Long Should One Charge a New Laptop Battery? ' eHow.com http://www.ehow.com/way_5261076_long-charge-new-laptop-battery.html#ixzz1GTAFQEz9
    Mar 13, 2011 | Acer Computers & Internet
    My dell axim does not charge a new battery- I tried 2 new ones.
    check the charging unit or the plug on ure phone,it mite be loose and not charging
    Sep 24, 2009 | Dell Axim X50 Pocket PC
    BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
    Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
    They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
    Razr V3 external battery charger
    May 27, 2009 | LG VX9400 Cellular Phone
    Battery is not charging for atv suzuki atv
    try replacing your rectifire becuase that is what charges the battery
    Mar 09, 2009 | 2001 Suzuki Burgman 250
    Charging new battery
    usually 8 hours.
    for first charge.
    on a brand new battery
    Jan 29, 2009 | IBM ThinkPad T41 Notebook
    Cell Phones Logo
    13 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
