Question about Samsung SF-3100 Plain Paper Inkjet Fax
SF-3100 Paper feed problem
Hi folks,
I've had this fax for some years now and have been very pleased with it, however lately it grabs several sheets when trying to send a multi page document. Have to feed it manually a page at a time. Very difficult. Is this a cleaning problem or does it require new rollers or something?
[email protected]
Many thanks
Jim Hartnell
  • jimwig Mar 30, 2008
    Hi Gravity001,
    You were spot on, many thanks, job done.
    jimwig
  • 51 Answers
You need to clean the friction pad. If you open the part where you put your sheets in to send faxes you will see a white pad behind the cover. You need to clean it, if it still feeds more than one page the pad is probably worn.
Posted on Mar 27, 2008
6ya staff
SOURCE:
How do I fix the paper feed mechanism
Try to rep[lace the paper separation rubber.
May 21, 2014 | Brother IntelliFAX 2800 Laser Fax
How do i print the memory
You can download the SF-3100 user manual here:
http://www.retrevo.com/s/samsung+sf+3100+fax+manual
which will tell you how to print the memory and everything else you need to know in order to use it.
May 27, 2010 | Samsung SF-3100 Plain Paper Inkjet Fax
I need a user manual please. thks, edgar
go here : http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SF-3100-_D
Nov 07, 2009 | Samsung SF-3100 Plain Paper Inkjet Fax
Front loading page grab problems.
See that top on which to place paper faxing is a green button should be positioned (to the right or left) in position with several sheets drawn as an indicator. I guess yours is positioned on a single paper which means it does not separate anything you ask.
Good luck to configuration
Oct 30, 2009 | HP LaserJet 3200se Printer
Paper will not feed through - Samsung SF-4500c FAX
try isopropyl alcohol it may work for awhile depending on how smooth the tires are, you can replace them:
try this site
precisionroller.com
Aug 12, 2008 | Samsung SF-4500 Plain Paper Thermal Fax
Owners manual
Hi tedkollias40
Here is your fax machines manual
Thankyou for using FixYa, a FixYa rating would be great for tracking this down for you. Cheers :)
regards
robotek
May 08, 2008 | Samsung SF-3100 Plain Paper Inkjet Fax
Fax chews paper when receiving a fax, sends perfectly
Where it is receiving the fax and sending it are 2 different locations.
There must be a piece of paper in the paper path causing it to get "concertinaed ?????
when sending it is NOT going trough the same path.
Here is the manual, there may be some help in the troubleshooting section
http://www.retrevo.com/s/samsung+SF-3100T+manual
good luck
Dec 22, 2007 | Office Equipment & Supplies
Samsung SF-3100T parts
Hi there the thing is if you were to glue this back into place the likely hood is that the machine will not hold as there is a quite a bit of pressure within that area. The best option is to obtain a new machine as trying to fix will out way the cost of the machine.
Thanks J
(Sorry cannot help anymore)
May 28, 2007 | Samsung SF-3100 Plain Paper Inkjet Fax
Samsung SF-3100 Plain Paper Inkjet Fax Logo
154 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
