Question about Garden
We are able to start it but not able to get the water to circulate and come thru the wand. This is a portable power washer and only about 4 years old and used very little. When we started it this last time a little water came out of the wand but then this plug on the bottom went flying off killing any pressure built up with it running.
  • Bill Phillips May 11, 2010
    What kind of pressure washer is it?
  • 98 Answers
Replace the plug. remove the wand and force water back through it to unplug it and the hose.
if you have a water filter on that machine i suggest cleaning it out.
Posted on Feb 20, 2010
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Sears 2550 psi power washer does not have any water flow with the motor running, but has a low flow from the wand when the motor is off.
If this unit has set for that long has you have rust inthe end of the nozzle. take it of or undo the wane and soak it in CLR this will take the rust out. GOOD LUCK....
May 19, 2014 | Briggs Stratton 020273 Elite Series...
I cant start my power washer. the pull start is locked and wont release to start engine.
When the pull start gets locked, you have to release water pressure from the wand. I had the same problem last year.
Jun 16, 2013 | Craftsman 2700 PSI Briggs Stratton...
How do I winterize a Briggs and Stratton pressure washer
Change engine oil, add fresh stabilized fuel,start and run to circulate new fuel. Use a section of hose and pump som RV antifreeze (the pink stuff) through your pump and hose if you are leaving your hose and wand hooked up.
Hope this helped
Nov 03, 2010 | Briggs Stratton 020273 Elite Series...
Coleman 1210 power washer no water comes out of gun
I've never used it before what plugs in where, the 1210 powermate, Pictures would help
Jun 01, 2009 | Coleman Pressure Washer PW0881800
Pressure washer - no water flow
Is there a check valve on the hose inlet that is stuck, and won't let the water in???????
May 25, 2009 | Plumbing
Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Apr 24, 2009 | Garden
Power washer problem no pump action
sounds like nozzle is blocked.small bits of grit jam nozzle unscrew and make sure its clear turn water on and pull trigger to see if gun trigger works,then refit nozzle check again for spray.if clear start up and try out.if no go then pump probably needs cleaning and relubing seals.
Apr 20, 2009 | Comet Garden
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
