Question about TVonics STB100 Freeview DTV Receiver
TVonics Model: DVR-FP250 There was a power failure and all the light went off in the house . When the electricity came back on I switch on TVonics. A notice was showing, advicing that there was a failure and I needed to format the harddrive. I said OK, after a wait, it said there was still a problem and kept asking to format the harddrive. After several tries I give up. I can get the Freeview channels but no access to the harddrive. I would be pleased if you could help me in this matter. Yours Norman
3 Suggested Answers
SOURCE: just installed new tvonics250 freeview + box
I have one of these boxes and one of the things which has caught me out a couple of times is that the remote can control three devices. To turn the Z250 on and off you may need to press the DTR button at the top of the remote first. When you press the on/off button on the remote the DTR button should light up red to let you know the signal is being sent to the Z250.
You are probably aware of this but just in case you weren't
Posted on Jul 05, 2009
SOURCE: TVonics DVR FP 250 hard drive fault
Thanks everyone, a new A/C adaptor 12v.regulated 3600mA from Maplins, Maplins No. L48BQ at £16.99 brought my TVonics box back from the dead! It has an output which will easily cope with the required 2 Amps, which is beyond most plug-in PSU's. Just make sure that you SET THE TIP POLARITY correctly. Once again thanks for that, you've all saved me £200+
Posted on Jun 26, 2010
After power failure - I am getting no signal on monitor
After power failure at my house when power came back on my security zmodo dvr monitor didn't come back on it said no signal
Jan 19, 2015 | Zmodo Surveillance cm-Z2212GY Weatherproof...
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Where can I find a tvonics DTR-Z250 user manual please
TVonics was taken over by Pulse Eight! I could only find DTR-Z250 manual! Hope this helps! Link below!
http://soapdrama.co.uk/downloads/dtr-hv250/documentation/DTR-HV250_User_Guide_V2_final.pdf
Dec 14, 2014 | TVonics DTRZ250
I HAVE A JENNAIR JS42CSDBDA FRIDGE THAT WENT DEAD NO POWER,NO LIGHTS CHECKED OUTLET AND FOUND POWER GOING TO FRIDGE BUT NOTHING. IT ACTS AS IF IT'S NOT EVEN PLUGGED IN.
I am not familiar with this model BUT most fridge/freezers these days have a built-in electrical protection device [usually similar to a circuit-breaker] to protect the unit from any electrical supply surges and/or "shorts". You may find a RESET button located near the compressor housing. Press this and hopefully your problem will be rectified. Probably best to do this with the power switched OFF [although not always necessary].
Oct 20, 2014 | Jenn-Air Refrigerators
LG DVR lst-5403p won't power up
About the only thing you can hope for is the fuse inside got taken out.
Someone will have to open it and follow the power cord to it to find out.
Jun 11, 2012 | Televison & Video
The tail lights went out 2 days ago and we have checked all the fuses under the dash and the hood and we cant find the problem
Check for power and ground at the brake-light switch and the brake-lights. Common failures are the brake-light housings (the circuit boards break inside) and the switch on the pedal.
May 02, 2010 | 1996 GMC Sonoma
Phillips dvr won't power up. Lost power at house
Try hooking it up to another (working) electrical outlet. If that doesn't work, there's several possible problems.
The most likely is that the box was fried when a larger-than-usual current traveled down the line (or even down the coax if lightning struck and your system isn't adequately grounded); the electrical outlet is either pushing too much or too little power; or your house's ground polarity is reversed.
More than likely your box is bad. If you don't know very much about electrical systems, don't go messing with your ground or any outlets without a wall plate.
Dec 26, 2009 | Philips DIRECTV R15
Power went off in house when it came back on the green light on the front panel keeps blinking will not stop Mitsubishi Bigscreen model ws- 65909
I've got a 65535. When this happens, you can sometimes press the On-Off button for 10-15 secs until the light goes off. If that doesn't work, then unplug the tv for 30 seconds or so, then plug back in.
These sets are known to have power supply issues, and the blinking light may be a coincidence to the power supply failure. It's fairly easy to repair if you know how to solder.
Dec 10, 2009 | Televison & Video
This is a indication of a hard drive failure you could run a program called spinright on this its a small investment of $50 bucks but does save hard drives and 9 times out of 10 puts them back in business. But when in doubt replace the hard drive as if trying the format it does not work its safe to assume that you need a new drive. Thanks please do rate.
Aug 31, 2009 | TVonics STB100 Freeview DTV Receiver
TVonics STB100 Freeview DTV Receiver Logo
152 people viewed this question
Top TVonics Televison & Video Experts
 Mikey
Mikey
Are you a TVonics Televison and Video Expert? Answer questions, earn points and help others
