Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony projection television lamp replacement...
I have a Sony projection television that has the message "Lamp is nearing end of life, please replace." This message has been appearing for the last month.
Two questions:
How long do I have before this lamp dies? I am already seeing a little distorted color on the top of tv, nothing bad but I can see it coming.
Do I need to replace the full assembly or just the lamp. When I went to eBay to purchase, I noticed that the assembly had the housing as well as the lamp. Then I seen just the lamp. Any special reason why I would need the housing and lamp?
More info:
The television is two years old and runs great, no other problems.
  • Jennifer DeLaCruz
    Jennifer DeLaCruz Nov 18, 2009
    Hi Shaun, thank you for your response. Is there a life expectancy time allowance for the lamp, say, from the time I seen the message to it burning out? I would like to use it till it dies and get my mony worth...haha!
  • Sony Master
  • 1,525 Answers
Hello the last light at the bottom of the tv will flash this will tell you the lamp as burn't out i would buy the lamp in the housing it just makes it easyier to install when you do install it make sure
Posted on Nov 17, 2009
Testimonial: "Thanks Shaun! Great tips!"
  • shaun taylor Nov 18, 2009
    the lamp fitted securely and the lamp cover is fitted securely as well good luck
    shaun
    there is a lamp counter on the set,
    1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
    2. Step 2
      Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
    3. Step 3
      Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.this might tell how long it's got left
    shaun
My TV model number KDF 46E2000. I am getting a message in my TV "Projection lamp is nearing end of life. Please replace the lamp" . Please let me know what to do.
replace the bulb if picture is getting dim. the set is programmed to say this ever so many hours. if u got a manual it tells u how to reset this
Feb 15, 2011 | Sony KDF46E2000 46" Projection HDTV
How does one rid of the "projection lamp is nearing end of life" after an otherwise successful replacement?
Just used the box that came in with the new projection lamp.Take the old projection lamp put it into that box.Put it in the trash recycle bin,that how u get rid of it.
Oct 19, 2010 | Sony KDF-50E2000 50" HDTV
Getting a message that my lamp is nearing the end of it's life. I have 4 questions: 1. How long do you think I have until it will burn out. 2. Is there only 1 bulb/lamp that will need to be replaced. 3....
Hi, my same Sony KDF 50e2000 has been giving me the "proj lamp near end of life" message for approx 6 months-and we watch a lot of tv/play wii. I just ordered a repl lamp on line
Sep 01, 2010 | Sony KDF-50E2000 50" HDTV
I have a sony tv, model number KDF60WF655... i turn the tv on and it turns on for about 1 min then turns off, the green light flashes several times then turns itself on again. the process keeps repeating...
Replace lamp in tv as this symptom shows existing lamp is near to end of its working hours life span and need to be replaced.
Lamp replacement procedure is easy and would be written in user manual.
Buy Sony original lamp for good picture in tv.
Thanks.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
What does it mean by projection lamp is nearing end of life? how can i fix this?
Ur tv have bulb,it a lamp that project the picture.It have life spans about 1400 hundred hours.It come close to the time near the end.Change another lamp when the front LED lamp indicator flashes.
Mar 17, 2010 | Sony KDF46E2000 46" Projection HDTV
Sony projection lamp is nearing end of life
Here is a link to a website that sells the replacement lamp for $99 dollars. http://electrified.com/Catalog/Items/?CampaignID=Dealtime&ItemID=36414
There might be a local store in your area that carries replacement lamps but probably will not have yours in stock and would have to order it. After you replace the lamp you will need to reset the lamp timer for your TV using the lamp replacement option on the TV general settings menu.
Jan 09, 2010 | Sony KDF46E2000 46" Projection HDTV
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
449 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
