Question about Maytag PYE2300AY Electric Dryer
My Maytag Performa PYE2300AYW keeps running and won't get to hot on low but on Regular it gets too hot
    President:
  • Maytag Master
  • 1,922 Answers
Your cycling sensor thermostat is getting defective it will have 1 side a red wire coming off the heat selector switch and the opposite side will be a yellow wire from the safety thermostat connection
Posted on Nov 17, 2009
Can I reverse the door swing on my Maytag Performa dryer>
http://www.maytag.com/-[PYE2300AYW]-1109316/PYE2300AYW/
Here is the link to the owners manual. This feature is not mentioned. Look at the molding in the metal case of the front of the dryer. See if there are identical moldings for the door and latch on both sides. If not, no. Only alternative is to get longer connection hoses and swap washer with dryer left to right.
Dec 24, 2014 | Maytag Dryers
I have a maytag performa electric dryer model #pye2300ayw, rev 10 -- sometimes I need to run the dryer 3-4 times to get a load dried. I checked the outside vent and there is alot of hot air coming out, the...
We had this same problem recently. Don't know if your problem is the same, but I am sure it could be.
While we did have hot air coming from the outside vent, it was still a restricted vent duct that was our problem. I went to Lowes and bought a dryer vent cleaning kit for about $40 (I figured I needed to do this anyway, as I'd been hearing about how many housefires are caused by the heat buildup from poorly breathing vent tubes/ducts), and cleaned the whole length of the duct (and replaced the plastic flexi-tube inside with a metal one).
I had thought I had good air-flow before doing this, but oh my gosh, what a difference this made! And I couldn't believe the pile of nasty, damp lint that came out!!
Anyway, our dryer immediately went from requiring 2-3 cycles to dry a load of clothes, to doing a great job the first time through! Perhaps the same solution would help you. I hope so!
May 29, 2010 | Maytag Dryers
Where is the tumbler belt located on a Matag Performa Dryer model # PYE2300AYW?
www.servicematters.com/maytag_library/docs/16023083.pdf
service and repair manual above, everything is in there.
May 13, 2010 | Maytag Performa PAV2200
Maytag performa dryer model pye2300ayw, what should the ohms reading be on the thermal fuse?
doesn't matter,it's either good or bad,when you touch the meter to it if it reads 1 and doen't move it's bad if you get any reading it's good,if the dryer is loaded with lint in the duct that the lint filter slides into and the vent line is blocked it will keep popping on you, clean out the dryer,number one cause for popping the thermal fuse
Feb 22, 2010 | Maytag Dryers
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
WILL NOT START. LIGHT ON BUT WILL NOT START
Check the thermal fuse, located on the right side of the heater housing. If bad order LA1053 kit.
Fair warning it's a real patience tester to install correctly
Oct 16, 2008 | Maytag Dryers
Maytag PYE2300AY Electric Dryer Logo
369 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
