Question about Pioneer CDJ-800 Turntable
Turntable will not spin. belt off. how to replace belt which I found loose under turntable
  • 460 Answers
If you can obtain a neoprene belt it is simple. first put the belt around the table inner bottom ring holding a little of the belt with a finger stretch it a little and put it around the drive motor and drop the bable onto the spindle and you are done..bye
Posted on Nov 15, 2009
My Philco 841205 Turntable spins normally, but
If this is a belt driven turntable then when the arm rests on the record the weight cause the belt to loose traction and slip around. The only cure is a new belt. Make a note of how the belt fits before removing as the biggest problem with belt turntables is knowing how the belt fits. When removed. Measure the diameter of the belt in MM and then the thickness. You won't need to be spot on with the diameter. Put the measurments into Google with the words turntable belt. Get the one that is nearest your measurements.
Sep 16, 2014 | Audio Players & Recorders
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
Has power but wont spin
Hi,Dead as in no power up or dead as in the turntable will not spin?? If the turntable isn't spinning check and see if you have a direct drive or belt driven.Getting back to your turntable, if it is belt driven your belt may have become dried rotted. replacements are available at
elexatelier.com/ ,
elexatelier.com/ or
needledoctor.com ... good luck, definitely worth getting it up and running again...
Have a nice day..
Feb 17, 2011 | Numark TT200 Turntable
I just bought a used DP26F and see that under the platter the belt goes around only a spinning thing (sorry) near the front, but nothing else. Something must be connected to whatever it is that spins the...
This picture is from the manual for a DP-29F, a similar belt-drive turntable:
The view is through the rectangular hole in the platter you see with the turntable mat removed. This picture is from the setup section for a new turntable, so the ribbon tape won't be on your belt. But it shows how the belt should go around the drive roller (it's the shaft of the drive motor underneath). Other than the routing of the belt over the roller, there's nothing else to connect. If the belt is working correctly (hasn't stretched so it's too loose), the roller drives the belt which in turn spins the platter. If your turntable isn't turning, either the belt is too loose to transmit the motion, the drive motor isn't spinning, or something is binding and preventing the platter from turning.
Jan 20, 2011 | Denon DP-26F Turntable
HOW DO I INSTALL A TURNTABLE BELT FOR A SONY TURNTABLE
Under the felt of the turning section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 30, 2010 | Sony PS-LX250H Turntable
Turntable belt is off.
Under the felt of the turning platter section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 16, 2010 | Teac GF-600 Turntable
Turntable spinning too fast
The turntable speed is controlled by a belt, which is virtually a big rubber band. If it spinning too fast , then this means the belt is too tight. The only way this can happen is for the unit to be fitted with an incorrect size belt. You didn't say if you have a new unit, or a second-hand one, or if it has recently had the belt replaced. If it is a new unit and still under warranty, take it back to the retailer and ask them to fix it for you. Again, if you have recently had the belt replaced, take it back and ask them to do the job again, and this time to please use the correct belt. Be polite but firm....If you are a handyman, the job is not too hard to do yourself, and if you need any extra help, just ask, johnatwagga@yahoo.com. To buy the correct belt, you will need the name, model number, and preferably, the serial number. All of these can be found on the back of the unit. Good luck, and I hope this helps.
Nov 24, 2008 | Teac GF-350 CD Shelf System
Turntable Spinning too fast
ya buy new belt loose or is this direct drive
Oct 09, 2008 | Teac GF-350 CD Shelf System
Pioneer CDJ-800 Turntable Logo
115 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
