Question about Food Mixers
Bits of flour are too s--l- to stay in a large-holed sieve
  • 251 Answers
Use a smaller holed sieve or use a coarser grade of flour
Posted on Nov 15, 2009
How can I remove K beater from my Kenwood patissier which is jammed
Only a bit of CRC and some brute force is going to work. Unplug the machine. Remove the bowl, lock the head down, squirt some CRC around the top of the paddle where the shaft goes in. Get someone to hold the mixer from moving about then grip the paddle firmly with 2 hands and turn it left and right. Gradually you will begin to get increasing movement until in the end you will be able to unlock it from the shaft. Once it is off you will need to thoroughly clean the shaft then you will need to scrape out the inside of the hole in the paddle. I carefully use a small round file, I am trying to clean the hole out, not increase the size of it beyond what originally was. The hole size has become smaller over time because of flour or similar entering around the shaft during use.
Mar 01, 2015 | Kenwood Food Mixers
I cannot remove the paddle from my Hobart stand mixer. I was making a very large batch of cookies and when I finished the paddle would not come off. I put the paddle on just before starting the cooki
Get some CRC into the top between shaft and paddle socket and in and around that driving lug on the side. Then grasp the paddle with a hand on either side and rock (turn) it back and forth as forcefully as you can until it starts to come free. Eventually it will start to move and you will be able to remove it. Polish the shaft and scrape out the hole, it is flour that has wafted in there that has tightened it up, it packs & embeds itself into the aluminium paddle.
Dec 10, 2014 | Hobart Food Mixers
I can't get the dough attachment off my Kitchenaid stand mixer. I have tried oil, filling up the bowl with soapy water and letting it stand overnight, pouring teapot after teapot of boiling water ove
Hi Georgette
You need to encourage movement between the beater and the silver shaft it locks on to. There is nothing that you can unscrew to make it easier. Get a can of CRC and try & get it around the silver shaft at the top of the beater plus you should be able to get a bit in that side slot where the beater engages with that driving pin. Rock (twist) the beater side to side and slowly the grip will loosen and you will be able to encourage it off. Once you have it off you will need to clean out the CRC and polish up that silver shaft. Next is the more difficult part, you need to polish up that hole in the beater. What you are trying to do is remove the build up of flour in the hole so that it is pretty much shiny in there again without being significantly bigger than it was originally. I use a rat tail (round) file to do this job, you are just removing the darker build up in there. When done a good wash and dry and it will be like new again. Keep the hole clean of flour and it may not happen again.
Nov 30, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Blade is stuck in shaft of kitchen aid
Get some CRC around the shaft and into the beater hole and wriggle it about until it comes free. Rasp the build up in the beater hole out with a round file and clean up the shaft on the mixer. Remember you are cleaning out the hole not trying to make it bigger than it was. In my experience it is a build up of flour in there bonding itself to the hole in the aluminium beater.
Aug 31, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Cannot get paddle to release from beater shaft
A bit if CRC and a lot of wriggling will get it off then a quick rubbing through the hole with a round file. Then make sure the shaft is perfectly clean. I think over time flour gets on the hole and tightens up the hole. You need to put a fair effort into the wriggling bit to get it off but easy fix after that.
Jul 10, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Flat beater will not push up for removal
Try and get some CRC into it, lots of grunting, pushing and wriggling and it should move. Then clean it all out with a paper towel, maybe a LIGHT rasping in the beater hole with a nail file or similar, you just want to shine it up not really make it bigger. Strangely flour gets in there and over time tightens the hole up.
Oct 31, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Blades stuck
CRC and wriggling, twisting, pushing and grunting. Then when it's off clean out the hole and shine the shaft. Try and polish the hole without making it bigger, food builds up on the aluminium surface and a bit of extra flour locks it on.
Aug 17, 2013 | KitchenAid K45SS Classic Stand Mixer
Can't get my beater off my KitchenAid 350 Watts mixer
The button does not retract, a bit of CRC may help combined with a lot of wriggling and grunting. Flour gets in there over time and builds up and makes the paddle tight. Rasp it out a bit in the hole, try not to remove metal, you just want to remove the buildup. If you had a bottle brush that fitted and cleaned it in there each time it will never happen again. Look how long it has taken so far.
Dec 25, 2012 | KitchenAid KSM50PR Professional Series...
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
How do you use the KitchenAid SNFGA Pasta Maker Attachment
If it's gumming up, the dough is too wet and needs to be dried out more by adding flour. The right consistency dough is such that if you tear off a small piece and then tear it in half and squeeze it back together with your fingers it should stick back together but not stay stuck to your fingers. If it stays stuck to your fingers it's too wet and needs more flour. If it is crumbly, it's too dry and needs more water.
Apr 24, 2010 | KitchenAid K45SS Classic Stand Mixer
Food Mixers Logo
24 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
