Question about Bissell 8910 ProHeat Clear View Upright Vacuum
No suction in hose - Bissell 8910 ProHeat Clear View Upright Vacuum
    Problem Solver:
  • 13 Answers
You must have a restriction in the hose. Take a hanger or a dowel rod and posh it through the hose to find what might be stuck causing no suction. Also turn the vacuum upside down and check to see if there is something clogging up the entrance into the hose.
Posted on Nov 15, 2009
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
Riccar 8995 no suction in hose
drop a quater thru hose make sure it goes thru
May 18, 2014 | Riccar Vacuums
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
How do I switch the vacuum from floor to accessory suction
It automatically switches over when you disconnect the hose from the power nozzle. No suction it getting to the power nozzle, so the suction is only through the attachments. If there is no suction through the hose, check for clogs in the hose and in the tank where the hose plugs in. Also, check the screen at the bottom of the tank. If there is a clog in the hose or tank, then there also will be no suction to the power nozzle.
Remove all clogs and you should get suction.
Dec 19, 2010 | Hoover U5721-900 WindTunnel Upright Vacuum
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
Oct 21, 2010 | Oreck Vacuums
Dyson hose does not produce alot of suction when extended.
Hi its Darran at Dyson.
It sounds as though the wand/hose is blocked. with the machine locked in the upright positino, remove the hose from the machine, switch on and test the suction. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If the suction is strong, you will need to check the wand for a blockage. If the suction is still poor, check the hose for a blockage.
You may find it useful to wash the filter as this can sometimes cause a drop in performance if its dirty and it wuold be more noticable from the hose.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Feb 19, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
My DC17 suction hose doesn't have any suction occasionally.
check the seal on the filter is not broken,And check for any blockage at the bottom of the pickup pipe.
Nov 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
I have little suction when using the hose attachment
Check the hose for a blockage. If you remove the hose, if there is suction at the point where the hose hooks to the back of the vac, then the hose is clogged. If no suction there, check filters, make sure they are clean.
May 31, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Reverse Suction
You have a clog either at the inlet by the brush roll or in the hose. Pull the hose and check for suction at the end of the hose, If it is ok there, then you have a clog from where the hose hooked into and the inlet at the bottom. If at the end of the hose there is no suction, take the hose off and see if you see a clog in it. If no clog there, then check all filters, if they get clogged, then air can't flow thru them and no suction.
Dec 31, 2007 | Hoover U5507900 Elite Rewind Bagless...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
59 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
