Question about Compaq Computers & Internet
I have a Presario F500 Laptop. My problem is the computer attemps to start up when pushing the power button, but the sceen never shows anything and the fan comes on breifly and then it just shuts off completelt. Is this worth fixing or get a new one?
  • 54 Answers
Remove all components (battery, RAM, WiFi card, Modem Card, Ethernet Card), plug the AC adapter and try power. If the symptom is same, then you have dead motherboard, more likely BDU chip. Expect to spend at least couple of hundreds at local computer shops.
Posted on Nov 16, 2009
  • PCShare.Com
    PCShare.Com Nov 17, 2009
    bhagyavichar,
    This guy has laptop, not desktop/tower. Your description is more copy/paste generic and most of it does not apply to his question.
    Scholar:
  • 26 Answers
Ok. I have this exact same laptop and the exact same issue. Go to hplies.com and you will see almost 2,000 users with the same issue. The problem lies with the nVIDIA GFX chip on the motherboard. THE ISSUE IS UNREPAIRABLE. Any repairs will force the laptop to fail again.
This issue has actually landed me in small claims court where I am suing for hte full cost of this laptop because not only is hte laptop defective, nVIDIA admitted it, and HP covered it up.
Join us at hplies.com and we will give you the know how to get this issue fixed/your $ back. We even have links to all of the information!
Posted on Jan 09, 2010
    President:
  • 414 Answers
Probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)in power on mode, open/unplug the data/vga cable of the monitor fromcabinet..see if raster or 'osd' is appearing on the monitor screen..ifso monitor is ok..else replace the monitor and see..
2) if u hv a graphics card, replace with a standby or onboard and see..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)seeif the ram(s) is loose/faulty..open clean/remove carbon & or oxideformed on the teeth with an eraser n resit it..or replace with a standbyn see..
5) a) see if ur hdd is noisy or emitting any 'ticking'noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to breplaced..
6)remove/clean dust neatly..dust is non-uniform innature n may cause jam/short circuitry/excess resistance n manymore..resulting an increase in heat..
7) open the CPU Heat-Sinkwith fan out of the socket..put some "Heat Sink Compound" (available inlocal electronics chip level spare market) between the cpu/processor andthe CPU Heat Sink *** fan..resit/fit it tightly in position..
8)on main/mother board..see with a debug card for mb error..may bshort..look for defective capacitors(esp above1000mfd)/mosfets..gothrough the mb's south bridge n the circuit lie around atxconnector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smpsviz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue); -5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic', orpwm switching regulator circuit..look for defectiveprotector-transformer/resistance(esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
the Software part:..
1)hv a licensed and UPDATED antivirus installed (iprefer avg/kaspersky, remember, without updation a full version antivirusis useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeall the unnecessary startup items from here..(if u can't find whatto remove, post me/us in ur comment with all the items listed in eachn every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6)disable the following:..
a)'Automatically Restart' right click on mycomputer->properties->advanced->startup n recovery->(uncheckon the) Automatically Restart;
b)'Error Reporting' right click onmy computer->properties->advanced->error reporting->disableerror reporting->(uncheck on the) 'but notify me when criticalerror occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r bot a professional, always better to seek advise from ur system admin/vendor....
Why after replacing the LCD in my laptop, the computer will not power up?
Replacing LCD is a big job, try to dissasemble your laptop again and check ALL CONNECTIONS are they plugged in and secured properly. If it is not static damage to the main board (worst case scenario, but it could be anything else), I would concentrate on connections first.
Sep 16, 2014 | Compaq Presario F700 F500 Series Laptops
I have a Compaq Presario F500 When I press the power button all the lights light up for a few seconds then it shuts back off
remove the battery then try to plug the charger directly on your laptop without a battery.. to test if the battery is working properly. if not.. maybe your main board have a problem. just like athe compaq presario of my friend. also mainboard problem.
Jul 10, 2011 | HP Compaq Presario F500 F700 and G6000...
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
No touch pad response, no pointer
Boot in safe mode (hit F8 on system start-up). Then once in windows, use the system restore feature found in acessories>system tools once you click the start button.
Sep 21, 2009 | HP Compaq Presario F500 F700 and G6000...
Monitor on Compaq F500 doesn't power up.
check whether the display is coming on monitor or not through the vga port, if the display is there then its the problem of display panel, if not then the fault is in motherboard of the laptop
Sep 14, 2009 | Compaq Presario 700 470024-192 Notebook
Lights come on and off for a couple seconds but computer won't power up
Just the LED's blinking but can you hear the fan on the processor run? If not most likely your power supply, SMPS, has failed. However try starting it with a working one of the same capacity to check and then buy your own. However if your PC shows no change on using a working SMPS, the the problem could lie in the RAM sticks or MB...............sodeep
Jul 30, 2009 | HP Compaq Presario F500 F700 and G6000...
I need sound and display driver for Compaq Presario PC Notebook Compaq presario f500 laptop
Visit this compaq website : www.compaq.com then click on Get Support. On 1.Select a task choose Software & Driver Downloads and on 2.Enter a product number, type your laptop model "presario f500" and click on the submit button. Next is choose the exact model of your laptop then select your operating system. Hope this helps.
Jun 05, 2009 | Compaq Computers & Internet
Compaq Presario F500 - won't boot up - power and lights etc on, tries to start but cuts out after about a second I have the same problem, this F500 notebook is just getting me nuts and no, it is not...
check the power supply, either the power cord or your power supply in the laptop.
and NATurally..happens aFTER the warranty expires, that sounds about right.
Apr 13, 2009 | Computers & Internet
Computers & Internet Logo
1,498 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
