Question about Cameras
Clean sensor on canon eos30d - Cameras
    Brigadier General:
  • 11,967 Answers
Google the words...cleaning a digital slr sensor...you will find sites with complete directions and where you can get the supplies needed.
Posted on Nov 15, 2009
Plis help me my copy canon ir 4570indicators show the paper has jammed(paper stuck)when it was d check repeatedly ,cut no paper stuck again but the indicator still appears ,is there a solution for me
  • First clean the sensors
  • If Problem persists change Pickup rubbers.
  • If problem Occurs replace the pickups
  • Check and clean the Pickup sensor
  • Then check and clean registration(Steel rod) sensor
  • Then check and clean Fixing unit sensor.
  • And finally check and Clean the Delivery sensor.
  • Don't use air blowers and Hard cleaners just use cotton and brush.
Jun 21, 2016 | Canon Office Equipment & Supplies
The canon printer will only print the header and the body of a e mail
Remove the printer cover (left side), then clean the sensor vertically with wet tissue.
Important
When cleaning the sensor, not to remove line sensor, because it will be fatal. So, the cause of the damage, because the sensor is dirty, covered by ink. You must clean the ink that covers the sensor.
Nov 24, 2011 | Canon Office Equipment & Supplies
I want to download photos from my canon eos30d onto my mac computer but i dont have the software installed. what do i need to do/ what software do i need? Thanks
If your Mac does not have iPhoto, which is part of iLife from Apple, you can find the software from Canon USA here: 30D Eos
You will have to select the operating system on that page for the proper software
Jan 24, 2010 | Canon EOS 30D Digital Camera with 18-55mm...
I attached the Canon EOS30D to new computer before loading the EOS Utility. Now I get the message Camera not recognized when I attach to down load photos. Can I fix this?
When you installed the utility is not an issue...it doesn't matter. Microsoft updates often prevents some hardware such as your camera from being recognized. Why not use a separate card reader to download your pics?...works every time.
Jan 03, 2010 | Canon EOS 30D Body Only Digital Camera
How can i clean the sensor?
This is something that should be done by a specialist ,ie Canon repair.
However this can be done by yourself but is extremely risky.I clean my sensor but have learnt the hard way.
Here are some tips for you, i suggest you read carefully first - http://photo.net/equipment/digital/sensorcleaning/
This will apply to most dslr's though some have sensor self-cleaning within the menu.
If you decide to manually clean the sensor, i would suggest you use http://tinyurl.com/yhkweww make sure you list the Camera make and model.
Though accessing Mirror lockup in your menu and using a rocket blower may cure any problems you have.
Do NOT touch the sensor with the rocket blower.
I can guide you through the process, but would recommend you send the camera to Canon for a clean and service.
Nov 11, 2009 | Canon EOS 20Da Digital Camera
My software CD for EOS30D has been scratced and I need the software for another PC, where can I get it?
Please follow the below link to download drivers and other manuals for EOS30D
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=12929
Sep 09, 2009 | Cameras
Canon EOS 30D exposure metering not working
your ae sensor which is loacated on top of the pentaprizm , the reflex box , it has becomed unglued , it is located right in between the wiew finder and the reflex chamber
Feb 26, 2009 | Canon EOS 30D Body Only Digital Camera
Canon EOS30D: Overexposure in Auto Mode
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Jan 08, 2009 | Canon EOS 30D Body Only Digital Camera
Canon eos30d
Bent/broken card reader pins. Take a flash light and look inside the card reader. There you'll see two rows of pins, 1or 2 will be bent (common problem).
Needs repair service.
Oct 08, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Cameras Logo
50 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
