Question about Sony Ericsson K800i Cellular Phone
Problem with the applications in the memory stick(1gb) SE K800i Unit
I have a problem regarding some applications in my memory stick like the mobilemath and safe application.. i couldn't erase it, i tried it in file explorer but it cannot be seen, it is hidden i think.. same goes to the memory card reader i tried to go to the applications folder but the applications folder is not present.. it can only be seen in the phone browser but i couldn't delete it. Is this a virus since it replicates some of the applications and making it useless..
  • shadowprince Jan 11, 2008
    i have already solved it.. it needed to be flashed.. thats the only way you can remove corrupted files.. btw it wasnt the memory card, it was the phone that is infected.. thank you anyways.
Remove the memory stick from mobile & put in memory card reader then connect to PC & try to scan the memory stick with latest anti virus,clean it & check the status.
Posted on Jan 09, 2008
6ya staff
SOURCE:
Some vidoes display no files applicable
STOP
do not write anything to your camcorder's removable memory stick,otherwise you willt re-write the files and permanently lose your videos and pictures.
Install this recovery software called Tenorshare Data Recovery.
From inside the software,navigate/choose your memory stick letter( "D", "F", "G" ... ? ) and scan the section where it says "Raw Recovery", "Videos" or "Photos" . Scan the memory stick and Set the destination folder(folder where recovered files will be saved) somewhere on your computer.
BTW, you can get this recovery software from
Photo Recovery Software (for Windows)
Photo Recovery Software for Mac
It will show you thumbnails for your pictures that it found on your memory stick.
WARNING:there will be lots of recovered files,do not set the destination folder as your DESKTOP,otherwise you'll end up having 100000 files on your desktop... = total mess :)
Jul 19, 2012 | Sony HDR-SR10E HDD Camcorder
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
I upgraded the Android system for my sanyo zio and now i can't recieve any text messeges cause it says that the memory is full and it also says that my phone memory is full eventhough iv'e been erasing...
It seems most of you applications are stored in the Phone Memory and/or your application data is taking up lot of memory. You actually don't have to erase/uninstall applications. Please consider performing the following steps:
  1. Go to Settings --> Applications --> Manage Applications. In this Menu you'll be shown a list of applications. Use the Menu Button to "Sort by Size" and get a list of the applications sorted from high memory usage to low (phone memory). Once this is done, you'll be able to view the memory being used by each of the applications. Click on the applications which you see are consuming more memory and then use the "Clear Data" button to clean up the data being stored by the applications to free up memory. This clears up any cache, cookie, temp files associated with the applications. Depending on your android version, you may also see an additional button "Move to SD Card". The best option to get more space would be to use this button and move the application to the 4 GB SD Card storage.
  2. Optional Step if you do not have "Move to Phone/SD Card" option available - From the Android Market, download and install "App 2 SD Free". Once done, this application should help you free up a lot of space by moving applications from your phone memory to the SD card.
Hope this was helpful. If so, please consider rating this solution.
-thanks,
M
Mar 09, 2011 | Computers & Internet
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony Cyber-shot DSC-H7 Digital Camera
Is there anyway I can retrieve pictures that were accidently erased?
It may be possible to recover deleted pictures from your Sony Memory Stick by using the Memory Card File Rescueapplication. This software is available as a free download online in the Software & Drivers section.
If the Memory Stick File Rescue application is unable to recover the image files, then the Memory Stick media may need to be sent to a professional data recovery service company, like Sony Media Services or DriveSavers Data Recovery. For more information and pricing, visit the Sony Media Services Web site at http://www.sonymediaservices.com/, or the DriveSavers Data Recovery Web site at http://www.drivesavers.com.
Jan 01, 2011 | Olympus Camedia C-350 Digital Camera
Themes saved in memory card but i can't erase it
if the theme is not appearing in d file application then try to search it in phone memory and gallery...........................if not connect it 2 pc through a usb and delete the theme
Jun 04, 2009 | Nokia N73 Cellular Phone
I cannot open my inbox
If your memory stick is lower than 1Gb then try to upgrade it. Whenever you received mp3 or any data with higher memory consumption restore it to your memory card and delete the file immediately from your phone memory. This will might help your phone to ran out of memory.
Dec 05, 2008 | Sony Ericsson P990i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
83 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
