Question about Samsung HLT-5075S Television
When I turn on my samsung hlt 5075s tv, there is no picture, but all three lights are flashing
I have had success resolving this issue bu unplugging the tv for 10 minutes or so and then plugging it back in.
Posted on Jan 19, 2010
I have a samsung hlt5075sx and I have just replaced the lamp and it didnt fix my problem. I power on the tv and I can hear it humming to try and turn on, the lamp light blinks as it tries three times to...
I have seen this problem caused by a bad ballast or power supply board, I usually replace both at the same time, or a cooling fan is not coming on. Can be tricky trying to figure it out if you are not a technician.You can call 1-800-samsung to find the nearest service center.
Jul 05, 2011 | Samsung HLT-5075S Television
Tv will power up. no picture. red light flashing and one green light flashing
You need to change out the lamp. Lamps usually run around 180.00 to 200.00 and the manufacturer designed it to where you could change lamp yourself no tech required. Hope that helps.
May 16, 2011 | Samsung HLT-5075S Television
Samsung hlt5075sx/xaa no noise or picture The green light on front flashes 18 times then red flashes once goes through this three times then all three flash then center green comes on constant after that...
That model seems to have had a problem past and I would contact Samsung or a service engineer as it sounds in need of a repair to my mind.
Hope this helps........
Aug 28, 2017 | Samsung HLT-5075S Television
White dots all over screen
hi,
check ur cable connection first. if its also with dvd, the go for an extension box ( power strip) with. surge protection and emi filter.
if ur tv or any device comes with three pin connection ( three pin plug) then remove the ground from that socket also. i think white dot comes because of electrical interference. check all other power out lets for any loose contact.
then check again.
ok
Dec 31, 2010 | Samsung HLT-5075S Television
My Samsung Dlp model hlt5075s was working great with great picture for last 2 years. This afternoon I went to cut it on and it the three lights on the bottom right started blinking(standby, time, and...
The projection lamp life is over.2 years has not been replace projection lamp,tv on daily watches like 4 or 5 hours a day?u need to replaced the projection lamp.
Sep 12, 2010 | Samsung HLT-5075S Television
Tv will not turn on
There is a safety switch that is actuated when you install the lamp cover. It sounds like the switch has fallen apart and needs to be replaced. The unit will not turn on until the switch is replaced. You can call 1-800-samsung to find the nearest authorized service center.
Jul 08, 2010 | Samsung HLT-5075S Television
Samsung tv picture is off
If your tv is 3-5 years old and is still on the original bulb you most likely need a new lamp assembly
Tommy HD Installations
Feb 17, 2010 | Samsung HLT-5075S Television
Why don't my tv show a picture but all three light are flashing
samsung tv have a problem with color wheel,lamp,ballast.
Oct 05, 2009 | Samsung HLT-5075S Television
Color issues with tv after replacing lamp. Tv
no this is a main board problem you would need to replace the main board of you tv
Oct 02, 2009 | Samsung HLT-5075S Television
Samsung HLT-5075S Television Logo
419 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
